jmc
Elite Member
- Joined
- Jul 21, 2003
- Messages
- 3,106
- Location
- SW Indiana
- Tractor
- Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
With the inability in some cases to get a post hole digger to penetrate, or to peel up stubborn ice/dirt with a blade, it seems like power down on the 3 PH might be handy. I can see how it could get awkward to use with a back blade as the contour changes but this is just about the mechanical feasibility. Like most ideas under the sun, someone has probably tried it, but just in case, I'll try to describe what I think would work.
Add a heavy bar between the implement ends of the lower links.
Figure out a way to connect both the top link and a hydraulic cylinder to the top link attachment point on the tractor.
Connect the other end of the cylinder to the midpoint of the previously added bar.
Lower the 3 PH lever as far as possible. Extending the cylinder drives the lower links down while the top link and implement orientation follow passively as before.
Lifting the 3 PH requires some coordination though. Either you need to retract the 3 PH lever and cylinder lever simultaneously, or you need a float position on the cylinder control while you lift the 3 PH control.
Does this make sense?
John
John
