3 Cylinder Life
/ 3 Cylinder Life #1
holstein05
Bronze Member
Missouri
Quick question. Coming off of a farm I am used to the big machines with 3000-4000 hrs on a tractor not being all that unusual before an overhaul. Now however, I am looking at some 3 cylinder tractors (I'm no longer on the farm) for small jobs I have, and was just curious, what kind of Engine life do these smaller engines have?
Holstein05
/ 3 Cylinder Life #2
It will relate more to usage than # of cylinders. Utility tractors don't see near the heavily loaded hrs a field tractor does and normally see longer overhaul interval. 3k hrs for a is a might short for a properly maintained field tractor.
/ 3 Cylinder Life #3
I've got a '67 Massey 150 with Perkins 3 cylinder diesel, showing 2900 hours and still in the prime of it's life. Not at all uncommon for these engines to see 10,000 hours without overhaul.
/ 3 Cylinder Life #4
That's what I've heard also, 10,000 hour machines. /forums/images/graemlins/grin.gif
/ 3 Cylinder Life
10,000 hours? Wow, I like the sound of that!
Thanks guys.
What about the pros and cons of 4 cyl vs 3 cyl?
/ 3 Cylinder Life #6
Typically a 4 cylinder will run smoother BUT have less torque than an equally sized 3 cylinder.
KO
/ 3 Cylinder Life #7
</font><font color="blue" class="small">( am used to the big machines with 3000-4000 hrs on a tractor not being all that unusual before an overhaul )</font>
My ford 5000 is past that and runs good. I think you need to up that number to around 4-5K for harsh use, and 10000 for normal use.
I've even got gassers from the 50's and that era that made 4-5k and still have enough compression and oil pressure to do hobby farm work...
Soundguy
/ 3 Cylinder Life #8
I'll agree with everyone that the lack of heavy use or frequent abuse will add to life, but do think there are other factors:
1. Many of these machines are much higher RPMs than AG or commercial.
2. Many air-cooled engines run hotter than the oil or water cooled ones.
3. I have no idea of the target life these are designed for, but I'm not convinced it's the same as AG or commercial engines.
Anyway, I don't think you have a thing to worry about, but neither am I quite betting on 10K hours [in consumer targeted machines] until a few people have the clocks to prove it. /forums/images/graemlins/crazy.gif
/ 3 Cylinder Life #9
</font><font color="blue" class="small">( I'll agree with everyone that the lack of heavy use or frequent abuse will add to life, but do think there are other factors:
Anyway, I don't think you have a thing to worry about, but neither am I quite betting on 10K hours [in consumer targeted machines] until a few people have the clocks to prove it. /forums/images/graemlins/crazy.gif )</font>
Keep in mind that several tractors from the 1960's, 70's 80's and on into the 90's were BOTH "AG tractors AND 3-cylinders.
Ford 3000/3600/ect.
Massey 35/135/130/135/240/245/250/50/150
Deere used a few 3 cylinders, not sure of all the model #'s.
Point is, some of these tractors have spent 10,000 hours on farms as "chore tractors" and a few were even the #1 tractor on smaller farms. Come to KEntucky and see how many Ford and Massey utility tractors spent a lifetime on our tobacco farms.
They didn't get babied.
If I'm following your lead, you might be getting specific about 3-cylinders in TODAYS compacts, as opposed to 3-cylinders in general. Some of us were talking about 3 cylinders in general.
/ 3 Cylinder Life #10
Yeah, I know my points wander from the thread title, but thought I was going the same direction as everyone else! /forums/images/graemlins/crazy.gif
Anyway, what I'm saying is that 1,2,3 or many more cylinders isn't so much the issue as differences both in usage and design between AG & commericial machines [regarless of age] and the new ones targeted for the "consumer" market today.
/ 3 Cylinder Life #11
Ok, I guess it doesnt make sense to me.... /forums/images/graemlins/confused.gif
How could a 3cyl produce more Tq than a 4cyl? I honestly dont know any different, but I cant see logicaly how this would be true.. Anyone able to explain this?
/ 3 Cylinder Life #12
I'll take a stab at it ...
I believe the key bit of the comment was that a 3 cyl. makes more torque than a 4 cyl. of the same displacement
To get an engine of the same displacement with less cylinders, each of those cylinders must be of larger displacement. Larger displacement requires either larger diameter or longer stroke, or both. Both of those things will increase low end torque, especially the longer stroke.
... awaiting corrections ... /forums/images/graemlins/grin.gif
/ 3 Cylinder Life #13
OK, I'll buy that one... Missed the "equal size" part... Thanks..
/ 3 Cylinder Life #14
Years ago, I saw a small 3 cylinder Cat diesel that was driving a stationary generator... about the same sized engine as a CUT, but different operating situation, of course. The owner told me that such rigs typically get 12,000 hours between overhauls.
/ 3 Cylinder Life #15
There will be a relationship between the hours you work it AT EACH SESSION, and the total hours you will get out of it. A study of skid steer loaders recently showed that the loaders which were operated for short periods each time they were started, typically wore out the cylinders due to corrosive buildup, or something like that. It seems from memory that the cylinders develop a wear taper fairly rapidly if operated in this short-run manner. I will try to find the study I am (half) remembering...
Found this, not the article I was remembering, but well worth reading...
http://www.constructionequipment.com/article/CA6256027.html
/ 3 Cylinder Life #16
</font><font color="blue" class="small">( I'll take a stab at it ...
)</font>
Why does "cylinders" have anything to do with it? DISPLACEMENT! an 800 cy. in single cylinder can easily have more torque that a 3; 4 or 6 cylinder of say..?...50 cubic inches.
/ 3 Cylinder Life #17
I believe he was trying to say, that given 2 engines with equal displacement, the one with less cyls will have more torque.. etc
Soundguy
/ 3 Cylinder Life #18
So if I have this right an old two cylinder JD will out pull a six cylinder Oliver. Why doesn't anyone make a large two cylinder tractor anymore?
/ 3 Cylinder Life #19
If they are the both CID.. I'd say the 2 cyl should have more low end torque.. etc..
Chinese were sending over 2cyl diesels in the jinma line just recently..
Soundguy
/ 3 Cylinder Life #20
Right! The 2 cylinder will have a larger bore and much longer stroke to make up the same "X" CID.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Club Car (A59231)
Club Car (A59231)
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
2008 DOOSAN G25 GENERATOR (A58216)
2008 DOOSAN G25...
2020 SAVANA 3500 4X2 S/A 16FT BOX TRUCK (A59906)
2020 SAVANA 3500...
