3 cylinder diesel freeze plug removal
   / 3 cylinder diesel freeze plug removal #1
wschaftl
Eads, TN
Ford 2000 3 Cyl Diesel
Bought a freeze plug heater for my 1965 vintage 2000 3 cylinder diesel. How do I get the freeze plug out? It does not move when I beat on it. See pictures attached - this is on right side behind generator. Instructions from freeze plug heater say to hit one side with screw driver to push it in then grab with pliers on other side and pull it out.
Thanks for nay help.
   / 3 cylinder diesel freeze plug removal #2
That is a threaded plug. Don't try to beat it out. If you crack the casting you're screwed.
This is what a freeze plug you beat out looks like:
   / 3 cylinder diesel freeze plug removal #3
Which also means your new heater probably won't fit.
   / 3 cylinder diesel freeze plug removal #4
Being threaded, it's also not a freeze plug.
   / 3 cylinder diesel freeze plug removal #5
yep.. it's a casting core plug.
and as mentioned the early ones were threaded. I know 4-68 was a cutoff for many early options including tin louvers..e tc..
   / 3 cylinder diesel freeze plug removal #6
hopefully you havn't already damaged the plug or the threads ...
OK, well I suspected something was not right. My owners manual shows an optional coolant heater in that plug location - maybe that is only for later years. Don't think I have damaged it but will find out when I put the coolant back in and get it up to operating temperature. What kind of tool does it take to remove the screw in core plug?
   / 3 cylinder diesel freeze plug removal #8
A large nut of that size is usually twice as thick as that is deep which would leave enough exposed to use a wrench or socket on. Hopefully.
Also, look at the bottom of this page/link. Seems to be the heater you'll need.
Block Heater for Ford
I see what you are saying. It is a 1 inch hexagon opening so I can put a 1 inch nut in it and use a 1 inch socket to remove the plug. Good thinking - did not occur to me. Thanks for the link to the core plug heater. Looks like what I will need. I also bought a lower radiator hose heater in case I could not get the freeze plug out. I may just give that a try first.
Greatly appreciate your help.
   / 3 cylinder diesel freeze plug removal #10
otherwise, a large hex key or HK socket set.. etc.
I personally hate inverted head plugs.. :)
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
2006 Toyota Sienna Minivan (A42744)
2006 Toyota Sienna...
2012 KENWORTH T800 (INOPERABLE) (A45333)
2012 KENWORTH T800...
2014 FREIGHTLINER CORONADO (A45046)
2014 FREIGHTLINER...
2014 Jeep Grand Cherokee SUV (A44572)
2014 Jeep Grand...
2015 Ford F-150 Ext. Cab Pickup Truck (A44572)
2015 Ford F-150...
