3/8" Hitch Pins or attachment Pins?
   / 3/8" Hitch Pins or attachment Pins? #1
wmgeorge
Ankeny Iowa
JD650
Anybody know what Grade of steel they use on those pins? I really hated to drill out to 1/2 inch if those pins are Grade 5 or better. Working on the final details on my Thumb and need to attach to the dipper boom.
   / 3/8" Hitch Pins or attachment Pins? #2
I don't know the grade of small pins like that, but I wouldn't hesitate to go to 1/2" or even larger.
I presume the pins you refer too will take some kind of force and not just used for "parking" the thumb? It's not so much the shear strength of the small pins, but because of the small surface area touching vs force, hole elongation over time in the jaws or the pins bending will be a bigger problem, IMHO. It's easy to overlook or underestimate the torsional forces applied. Most of the smaller diameter pins are used for retaining purposes.
Thanks for the answer, I did go to 1/2 inch, just to make sure!
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2022...
CAT D8 (A58214)
CAT D8 (A58214)
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
