3/4 ton vs. 1 ton
   / 3/4 ton vs. 1 ton #1
Complete Turf Care
Veteran Member
South Louisiana
2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
I have been considering going from a 3/4 ton truck to a 1 ton truck.
My current daily driver/work truck is a 2012 Dodge 2500 4 door 4x4 with the 6.7L with 71,000 miles.
I found a 2012 Dodge 3500 4 door 4x4 with the 6.7L with 37,000 miles with a flatbed. The dealer has offered me the truck for a difference of $9000 including taxes.
Both are basically the same truck, with the same trim level, except for the mileage, and the flatbed, and the 3/4 ton vs. 1 ton. And the 1 ton needs the urea, the 3/4 ton does not.
Sometimes I feel that I would prefer a 1 ton flatbed for more towing stability, and a little more space on the bed. My current trailer hooked to the 1 ton would still be below CDL requirement, which I prefer.
What are issues I should be consider before making this move? Will I be happy with the performance, ride, economy of the bigger truck? Is the 1 ton worth that much more than my 3/4 ton now? Or in the future? What else?
   / 3/4 ton vs. 1 ton #2
Is the dually a 13? 12s don't need urea. I think the 9k is kinda steep to be getting into that truck but after my last batch of dodges I'm soured on them. When it comes to towing though, the dually does offer a lot of benefits. The flatbed is a blessing and a curse. You'll need to strap most things down, they are in plain sight and more often borrowed without the intention to return, but it makes hooking up to a gn easier and you don't worry about fenders or scratched up bed sides. L-shaped slip tanks fit better also.
Brett
   / 3/4 ton vs. 1 ton
Brett
It is a '12. I remember when I bought my '12 2500 the 3500's needed the urea but the 2500's didn't. I would put some removable sides on the bed. Maybe 12" high or so to help keep things from sliding off. Not sure what I would do for a tool box, but I will need something. It has 1 'underbody' box on it now, but that's not enough for all my junk.
   / 3/4 ton vs. 1 ton #4
I had a 11 3500 and 12 3500. Neither used the urea. What they have is a C&C 3500. could have the aisin transmissions and different gearing. C&Cs had the urea it'll also have those huge tow hooks off the front.
Brett
   / 3/4 ton vs. 1 ton #5
They were also detuned. Check what the hp/trq is. I'd bet it's considerably less than what you have now
Brett
   / 3/4 ton vs. 1 ton
What is C&C?
   / 3/4 ton vs. 1 ton #7
Cab and chassis. The work trucks that get flatbeds, utility body's, crane or bucket trucks.
Brett
   / 3/4 ton vs. 1 ton
Okay. How do I find the specs on this truck? I have the VIN. I'll look for a web site to decode the VIN
   / 3/4 ton vs. 1 ton
This is what I found. Anything here jump out at you that I should be concerned about?
VIN 3C7WDTCL4CG249958
Vehicle Description 2012 DODGE RAM 4X4 3500 CREW CAB CHASSIS
Monotone Paint
730 Amp Maintenance Free Battery
Anti-Lock 4-Wheel Disc Brakes
Front Height Adjust Shoulder Belts
Advanced Multistage Front Air Bags
Black Vinyl Floor Covering
Driver/Passenger Assist Handles
No Underseat Storage
5,500# Front Axle w/Hub Ext
Man Shift-On-The-Fly Transfer Case
4.10 Rear Axle Ratio
11.50, Dual Wheels Rear Axle
Anti-Spin Differential Rear Axle
Conventional Differential Frt Axle
Tinted Glass Windows
Rear Fixed Window
Rear View Day/Night Mirror
Passenger Side Sun Visor w/Mirror
Power Black Trailer Tow Mirrors
Sentry Key Theft Deterrent System
Dash Liner Insulation
Floor Tunnel Insulation
Instrument Panel Black Bezel
120 MPH Primary Speedometer
STANDARD EQUIPMENT
1 06/13/15
Var Intermittent Windshield Wipers
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Accessory Delay
Power Locks
Pwr Front Windows, 1-Touch,Up & Down
Rear Dome Lamp
Halogen Quad Headlamps
Automatic Headlamps
Clearance Lamps
Delete Cargo Lamp
Black Front Bumper
Body Color Headlamp Filler Panel
Front License Plate Bracket
Black Grille
Black Door Handles
Ram 3500 Badge
Front Air Dam
52 Gallon Rear Fuel Tank
Heavy Duty Engine Cooling
Bright White Clear Coat
2 Speakers
Uconnect 130 AM/FM/CD/MP3
Power Steering
4-Spoke Steering Wheel
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Rear Heavy Duty Stabilizer Bar
2 06/13/15
Tilt Steering Column
Delete Spare Tire
LT235/80R17E BSW All Season Tires
17X6.0 Steel Argent Wheels
Dual Rear Wheels
Non Adjustable Pedals
Delete Pickup Box
7 Pin Wiring Harness
English/USA Language
Job Rated
Seat Parts Module
Instrument Panel Parts Module
Door Parts Module
Front End Parts Module
Build To U.S. Mkt. Specifications
Incomplete Vehicle
U.S. Fleet Purchase
Zone 63-Dallas
Crew Cab
172.4" Wheelbase
DD/6340 Vehicle Family
Four Wheel Drive (4WD)/(4X4)
Price Class L
2012 Vehicle Specifications
3500 Series
Vehicle Order Tracking
U.S. Specifications Label
Texas Ship to State Code
Texas Sold to State Code
3 06/13/15
HD Vinyl 40/20/40 Split Bench Seat
Dark Slate/Medium Graystone
180 Amp Alternator
Rear Folding Seat
Base Door Trim Panel
Mini Floor Console
All Automatic Transmissions
6-Spd Auto AISIN AS68RC Transmission
6.7L I6 Cummins Turbo Diesel Engine
All Vehicles W/Power Mirrors
Remote Keyless Entry
Air Conditioning
Instrument Cluster w/Display
102 MPH Maximum Speed
Manual Adjust Seats
Vehicle Information Center
Ext. Mirrors w/Supplemental Signals
Exterior Mirrors Courtesy Lamps
Black Exterior Mirrors
Auxiliary Switches - I/P Mounted
Front Wheel Spats
Cummins Turbo Diesel Badge
50 State Emissions
Diesel Exhaust Brake
Auxiliary Transmission Oil Cooler
Exterior Mirrors w/Heating Element
OPTIONAL EQUIPMENT
4 06/13/15
Speed Control
Electronically Controlled Throttle
Current Generation Eng Controller
All Radio Equipped Vehicles
Fixed Long Mast Antenna
General Brand Tires
All Steel Wheels
Center Hub
Selective Catalytic Reduction (UREA)
Tip Start
Tow Hooks
Transfer Case Skid Plate Shield
Trailer Brake Control
6 Additional Gallons of Diesel Fuel
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
GVW Rating - 13000#
FAM: DD TRACKING: 10720T20 MY:2012
FAM: DD TRACKING: 20118T18 MY:2012
FAM: DD TRACKING: 10720T16 MY:2012
Customer Preferred Package 2GA
Customer Preferred Package 2TA
Price Protection - Code H
Fleet Incentive Waiver
Delete Group Funds-Fleet
Sold Vehicle
5 06/13/15
Fleet Option Editor
Fleet Sales Order
Special Scheduling Condition VI
4X4 Tracking
Misc Commercial Account
Saltillo Truck Assembly Plant
Waterbase Paint
All Inclusive VIP Program
Off Invoice Tracking
Fleet Matching System
   / 3/4 ton vs. 1 ton #10
Ok. From what I see...
Aisin transmission 3yr/180,000 mile warranty. Might still have some left
13k gvw. That's not bad. My 3500s were 12,200 I think
52 gallon fuel tank would be nice.
4.10 gears would help with towing but not kill mileage to bad
If I remeber right the numbers are 305/610 hp/trq. Or something around that. It's been to long since I studied up on them. When ram bought my lemon back in 2012 I considered a C&C but decided against it when I saw the power ratings and the fact I coukdnt get a longhorn Laramie. Instead got a regular dually with alcoas. This truck will probably ride more like a truck and feel gutless to you considering what your used to. I'd go drive it and see what you think. Still think paying 9k is a little high for some reason.
Brett
2023 LANDHONOR VPC-11-72W VIBRATORY PLATE COMPACTO (A51244)
2023 LANDHONOR...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
2021 Western Star 4700SF Tri Axle Dump (A47384)
2021 Western Star...
2016 Dodge Charger Sedan (A50324)
2016 Dodge Charger...
2013 BMW 528i Sedan (A50324)
2013 BMW 528i...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
