2WD vs. 4WD??
   / 2WD vs. 4WD?? #2
</font><font color="blue" class="small">( is 4WD important feature to have? )</font>
It just depends on what you're going to do with the tractor and what kind of terrain you'll be doing it in. It can be the equivalent of about 25% more power than a 2WD of the same size, it won't get stuck quite as easily and have to be pulled out and it's a help with a front end loader, so to me, it's important; might not be for your uses.
   / 2WD vs. 4WD?? #3
Terrain will play a big factor in 4WD . With any loads in the FEL , going down even a small incline , or rough terrain, you can get one of the rear wheels light enough to lose traction or you could get wheel hop.
I mow a 5 acer field that in on a incline.
I have had the rear wheel come up enough to loose traction using the finnish mower. That was with no FEL.
I am always in 4WD when I am mowing or in the woods.
With no brakes on the front wheels and you could find yourself changing your underware a lot.
Go with 4WD if you can afford it .
Dave in NH
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
Komatsu PC56 Excavator (A51573)
Komatsu PC56...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
