2wd vs 4wd
   / 2wd vs 4wd #1
Anonymous Poster
Epic Contributor
I am in the process of purchaseing a yanmar tractor.. but how do you decide which to get a 2 wheel drive or a 4.
   / 2wd vs 4wd #2
If you have any hills, wet spots, plan to remove snow, or any other traction concerns, get the 4wd.
Ed King
   / 2wd vs 4wd #3
This topic has generated some interesting discussions in the past. You might want to amuse yourself by reading the and <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=photos&Number=97849&page=&view=&sb=&o=&vc=1#Post97849>Why FWD threads.
   / 2wd vs 4wd #4
MFWD is the cheapest way to increase the "size" of your tractor. It's like adding 1/3 bigger engine and 1/4 more weight (and you never have too much of either).
   / 2wd vs 4wd #5
<font color=blue>...how do you decide which to get a 2 wheel drive or a 4. </font color=blue>
Very simple.. if you can afford 4WD, get it. /w3tcompact/icons/smile.gif
Bob
   / 2wd vs 4wd #6
I guess I'd ask the question - why WOULDN'T you want 4wd? You can always run in 2wd until you need 4wd, then you've got it. Yes, it is more expensive, but you sure can't add it later! As much as the extra cost is probably a concern, IMHO I'd be willing to give up a few hp to make sure I had 4wd. Just my $0.02 worth! /w3tcompact/icons/smile.gif
   / 2wd vs 4wd
To me no matter where you live you might as well buy a 4wd. The price difference is usually around $1000 sometimes less (depends on size). One big upside to 4wd is resale value. Around here if it ain't 4wd you ain't selling it.
   / 2wd vs 4wd #8
If you were just going to mow fairly flat land then you wouldn't need 4WD. If you are going to want to use ground contact implements then 4 WD is a big help. If your land is hilly or you have wet spots 4 WD is a big help. If you are going to plow snow 4WD is a big help. Older farm tractors managed to pull plows with 2WD but they were much heavier machines. With light weight small compacts 4WD is.....A BIG HELP.
Chris
   / 2wd vs 4wd
Flip a nickle. Then go buy the 4wd. nuff said. Dola
   / 2wd vs 4wd #10
kket56
Have you noticed any trend here? I have to agree with all the 4wd people, being one myself. It is a lot easier to pull a lever than to pull a tractor. This WILL happen. If you are considering a loader 4wd is an absolute necessity. If you are digging loose dirt 2wd is fine. If you try to push into compacted dirt or dirt with roots and such in it you need the 4wd to push into the pile. Many times I have picked up something heavy with loader then tried to back up just to have the rear wheels spin. (I know I should have balast but I don't always.) Just put in 4wd and back right up.
Going across a wet lawn in 4wd keeps the wheels from spinning and tearing up the grass. The 4wd also gives you additional wheel braking in real slippery conditions. You can pull more.
Best of all you can pull your 2wd friends out and 4WD tractors really LOOK COOL. /w3tcompact/icons/grin.gif
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
New Long Forks (A53002)
New Long Forks...
