2wd Always?
Status
Not open for further replies.
   / 2wd Always? #1
SLOBuds
Los Angeles/Central Coast, California
Kubota L35
Now that I'm an expert after operating my lifetime-first tractor for all of 27 hours ... couple of pretty dumb questions are surfacing at ramdom intervals. :rolleyes:
One has to do about when to use 2wd versus 4wd. My first approach was to basically always use 4wd because of its better traction. But now I see the obvious: 4wd introduces added drag/friction/whatever and therefore it is more economical to use 2wd.
Is that an accurate statement? Do you think it's best for me to operate in 2wd as much as possible and only engage 4wd under very limited circumstances when 2wd is bogged down or such?
I think I know the answer to this, but want to know if there are situations when I would use 4wd anyway - even if the tractor isn't slipping around.
Thanks.
   / 2wd Always? #2
Run 2wd unless the situation dictates 4wd...
   / 2wd Always? #4
I was having traction problems from lugging around a heavy mower on steep hills. Finally came to the conclusion that it was easier on the tractor to just leave it in 4WD all the time, instead of shifting in and out every 5 minutes.
Another thought is this: since the front hubs are always "locked in" on these things, it appears to me that you are always turning the front differential and driveshaft anyway, whether in 4WD or not. The only difference I can see in running 4WD is that you have the front end and rear end locked together, which might introduce a little more driveline and/or tire wear.
My question is, how much more wear are we talking about? Is it enough to actually cause some kind of problem over, say, a 20 year time of ownership?
The manual is silent on the issue, other than to say "don't run 4WD on hard surfaces" and "disengage MFWD when going to and from the work site to reduce tire wear".
   / 2wd Always? #5
Ditto. The situation includes not only you can't move in 2wd, but also moving with excessive wheel slip, i.e. heavy tillage for the size tractor. But be aware that in 4wd you can get so much traction you can damage an implement that gets stuck, when in 2wd it would have just stopped the tractor with the rear wheels spinning (and they don't spin real fast if you were in an appropriate gear).
Overuse of 4wd not only uses fuel but accelerates wear on everything, and on pavement could even cause damage to the driveline, just like with a 4wd pickup.
   / 2wd Always? #6
Here we go! This has been a hotly debated topic. I'd be surprised if this one went less than 4 pages.
Here's my first thought on this: Don't overthink it, because it really doesn't make that much difference.
Now, some practical issues. First, in addition to better traction, 4wd gives you breaking at all 4 tires which can be very important on hills, etc. As for economy, like evrything else, it just depends. The main thing that 'depends' is how big a deal is it for most of us even with diesel at $4 a gallon? If you have 10,000 acres to plow in Nebraska, that's one thing. If you bush hog with a 30hp tractor on the weekends, well, that's a another. And don't assume 2wd is universally more economical. Pulling a 2-14 plow with my tractor in 2wd requires more rpms and more audible work from the engine. In 4wd, rpms and effort drop considerably.
Now, here's my opinion about wear and tear. Forget about it. If you have a good, modern 4wd tractor, the front drivetrain is designed and built to the same specs as the rear. They are both meant to last the life of the tractor. What good is it to wear out a tractor engine, transmission and rear drive train and still have a pristine front drive train?
Some will also mention turning. My tractor has the same turning radius in 2 or 4wd. It is a bevel gear system and there is no palpable binding or torquing when turning in 4wd. Furthermore, the 4wd model turns tighter than the 2wd model of the same machine.
Okay, so I broke the first rule (don't over think it). Bottom line, use it all the time, never use it, or something in between. As long as you use your head, your tractor will be fine.
About the only time mine is out of 4wd is on the pavement.
   / 2wd Always? #7
Hey its your tractor, run it or tear it up like you want to..as far as wear and tear, Z-michigan pretty much summed it up! Any time you have more moving parts there is going to be wear! I hardly believe your tractor has the exact same turning radius in 4wd as in 2wd..but hey..its your story! I go back to my original response..Run 2wd unless the situation dictates 4wd
   / 2wd Always? #8
And everyone knows that leaving it in 4wd will tear it up.:confused:
That's exactly right. And given that logic, we should be recommending that no one crank their tractors.:D But in the end, you can't argue with the fact that if its moving it is being worn. So the next question is how much? And the answer to that question is.....not enough to matter.
Well, you might not believe the earth is round either, but that doesn't make it flat!:D My tractor has a bevel gear front drive system. There is no difference in feel or turning radius between 2 and 4wd. Sorry if that seems inconceivable, but welcome to the 20th century....Kubota has been making them this way for years.
And that's great advice. But it has absolutely no measurable advantage over the corrolary of always running it in 4wd unless the situation dictates 2wd...such as running on pavement.
   / 2wd Always? #9
Not everyone is aware that at least on most compacts the brakes only stop the rear wheels. Going downhill with a load in the bucket can demonstrate this real quick :eek: and is one reason I leave mine in 4wd unless on flat ground.
I personally don't see much reason to worry about having the tractor in 4wd when on softer surfaces.
Not sure how 4wd would change the turning radius? My tractor turns just as far left or right when in 2wd or 4wd, only difference I see is 4wd will chew up the turf a little more.
   / 2wd Always? #10
I use 4wd all the time unless I need 2wd, I have only been on pavement twice in three years, I can't remember if the 4wd handle goes up or down to disengagement.
I don't care if I wear out the ft. end I will just fix it if and when needed, I need the traction more than worrying about wear and fuel efficiency.
Status
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
