(2nd try) How do you climb down from a roof?
   / (2nd try) How do you climb down from a roof? #1
drssg
Veteran Member
Ohio
Kubota M5700, BX2350
My first attempt to post this got boogered some how, so I'm trying again.
I could use some very detailed instructions, preferably with pictures, on proper technique to get from the roof back onto the step ladder.
From a comfort level, I feel pretty good on the ladder and on the roof, but I get the heeby jeebies going right over to the edge of our 2nd floor roof to get back on the ladder. If I felt like I was using a proper technique, I think that would help my confidence.
I have some minor shingle repair work to do, so I'm hoping I don't have to get too carried away with safety equipment. But I'm not against buying some stuff, as I'd probably use it on other jobs.
   / (2nd try) How do you climb down from a roof? #2
Are you setting the step ladder on a 1st story roof? The only way I would do that is if I was able to just lean the step ladder up against the other roof without having to unfold the ladder. If it doesn't reach the roof then you are flirting with a serious injury. Buy a new extension ladder that will reach above the roof line at least 3 feet so you can grab hold of the top of the ladder as you step on to the first rung below the roof edge.
We also put extension ladders on 1st story roofs if we need to get up to a second story roof and it is the easiest way. Two ways to do it is to tie the ladder off to the wall with an anchor or nail a 2x4 into the roof your setting on to keep the feet from sliding. Nailinga 2x4 is acceptable if your replacing that roof but not so much if your just trying to get up to the second floor.
   / (2nd try) How do you climb down from a roof? #3
Pls post a pic of your situation. From the description, can't tell for sure what you have.
But you can jury rig some temporary "railing" to assist finding the ladder steps. Most often, coming down is the hairiest part of the whole ordeal.
Shouldn't be stepping down to a top stepladder step, so hopefully your step ladder is tall enough (either for two stories, or one story).
For sure, you want to do it so you cannot fall. (slight wink smiley here :) )
   / (2nd try) How do you climb down from a roof? #4
I only use a step ladder when it sticks up far enough above the edge of the roof that I can't miss it - otherwise I go with an extension ladder or my gorilla ladder, which is a cross between a step and an extension.
OTOH, I've been known to set an 8' step ladder in the bed of my truck so it would reach, but that's not safety police approved.
Thanks for the responses. I'll try to get a picture posted tomorrow to make it clearer.
I'm using an extension ladder (24' ?) to go directly from the ground to the 2nd floor roof. The ladder is long enough to reach the edge of the roof. And I have enough length that I can choose how far I want the ladder to extend beyond the gutter.
   / (2nd try) How do you climb down from a roof? #6
So you do not have a step ladder then and mean the step of the extension ladder?
If your using the extension ladder just raise it up 3' above the roof and then you just hold on to the top of the ladder as you step on to the first rung of the ladder below the roof edge. Also, tie the ladder off to the gutter as soon as you get up there the first time. This will keep the ladder from blowing over and help you also if you go to step on it and it slides for any particular reason.
   / (2nd try) How do you climb down from a roof? #7
Have a look at what I built for my ladder. I'm sure I didn't invent this. I even burnt it when I was done. It puts weight on the roof surface making it impossible for the ladder to shift. Someone tells us what it's called so we can find a better pic on the web.
[URL=http://smg.photobucket.com/albums/v347/sbattig/TBN/?action=view&current=roofladder.jpg][/URL]
It is actually attached to the ladder rungs via tin straps. You would have to swing like a monkey to have an accident. I carried some 80 bundles of shingles up to the roof on this.
This also saves your gutter by keeping the ladder off of it.
   / (2nd try) How do you climb down from a roof? #8
[URL="http://smg.photobucket.com/albums/v347/sbattig/TBN/?action=view&current=roofladder.jpg"][/URL]
Thats similar to a ladder stabilizer/stand off which is usually made of aluminum and designed to hook over two rungs
   / (2nd try) How do you climb down from a roof? #9
Even though you can get on the roof, you should have some extra support to keep safe. Here is what I would recommend, and I learned this from a firefighter. Use 4, 8 x cement blocks and put a rope through them, and throw the other end of the rope over the roof. When you climb the ladder, grab the rope, and either hold it tight, or tie it around yourself. Even if you fell, he said you would not pull those blocks up, and if you were so big that you could, it would be a gentle fall. I have tried it working on steep roofs, and it worked for me.
   / (2nd try) How do you climb down from a roof? #10
You need a longer ladder. I need at least 4 ft sticking up above the roof. I have tried stepping on ladders at roof level and it makes me really sick feeling. I wanna grab the ladder while still comfortably standing on the roof.
1998 Dodge Ram 3500 Extended Cab Pickup Truck (A44572)
1998 Dodge Ram...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A43004)
2017 KENWORTH T680...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A43004)
2016 VOLVO VNL...
SET OF (4) USES LOADER TIRES (A45046)
SET OF (4) USES...
MISC PALLET (A45333)
Library Smart Bins (A42745)
Library Smart Bins...
