2nd set of rear remotes on 4110
   / 2nd set of rear remotes on 4110 #1
jeff77indy
Grantsburg, IN.
2007 4110 Mahindra w/ M112 loader.
I'm looking to install a second set of auxiliary remotes on my new sheet metal 4110.
I have came up with a couple of Mahindra part numbers. These are 13305080160 and 1330508061, of which I have not came up with a vendor that has them. Anyone know if either of these are what I am looking for?
I have also came up with the part numbers that I believe I could make up my own "kit". None of the vendors I have looked into have any of these parts with the exception of possibly the valve.
Any help with this would be appreciated. Maybe a vendor here has the kit or components I am looking for.
   / 2nd set of rear remotes on 4110 #2
Good luck with that, 20 years ago I tried to get the linkage parts for my 4110 and no dealer across the country could come up with ANY of it. My factory installed rear valve is a 2-spool valve already, just needed the linkages to operate the second spool and of course I would have had to add hoses & disconnects that I could have sourced locally. Mahindra even had an exploded diagram showing all the parts necessary but totally unavailable.
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2011 Chevrolet Uplander Van (A51694)
2011 Chevrolet...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
Galvanized Livestock Gates - (2x Gates) (A55218)
Galvanized...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2013 CAT 246C (A47477)
