2N 4-Ring piston question
   / 2N 4-Ring piston question #1
DGaber
Mondovi, WI
Ford 2n
My 2N ran OK cold, then missed upon warmup. I suspected a sticky valve and/or compression issue. Compression is 90 in #1, 2, & 4 and nearly 0 in #3. Wet test brought #3 up to about 40. I have 35/20 psi oil pressure cold/hot, never smoked or used much oil. Tore it apart & found the sticky #3 intake valve. Also found that previous owner replaced #3 piston.
The original pistons are all 3 ring, and the newer one is a 4 ring. However, it only has rings on 1st (top), 2nd, and 4th (below pin) grooves. The bore still shows cross-hatching and ring end clearance is good. Is it possible that putting rings on all four might clear up compression problem?
   / 2N 4-Ring piston question #2
It won't hurt, I know that. The sticky valve could be the whole problem. I know of some hi performance engines that use only one or two rings. I would go with whatever the factory calls for.
   / 2N 4-Ring piston question #3
I agree... I'd scrub the valve stem down and get her moving free and perhaps hand lap it a bit.
4 ring pistons were the norm.. and then ford went to 3 ring.. less wear.
soundguy
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
Travel Trailer (A51694)
Travel Trailer...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
New Holland C238 (A50123)
New Holland C238...
400' Spool of 5/8"/16mm Crane Cable, New  (A52384)
400' Spool of...
