2cyl Perking trying to prime fuel line???
   / 2cyl Perking trying to prime fuel line??? #1
bob2299
Bronze Member
Canada Northern Ontario
Bobcat ct230, 35 hp Massey Furgeson 3Cyl Diesel
Hello Last year I put this tractor away and it worked
this year I replaced some fuel lines, and the fuel filter, then primed the line up to the 2 vent plug on the injection pump so upper and lower vent plug are fine fuel up to there.
Then loosen the three pressure line at the injector connection, and nothing, nothing.
and like I said last year it was working fine, I have prime this fule system in the past, once the fuel is at the injector pump lower and upper bleeding screws ussually it's all good
can any one help me
thnx.
   / 2cyl Perking trying to prime fuel line??? #2
Maybe an obvious question, but is there enough fuel in the tank to push it to the pump?
Sent from my LGL35G using TractorByNet
OK found out what I was doing wrong
once the injector pump has been bled, and that the upper and lower bleeder screws have no air, just turn the key and wait until the fuel goes up the lines, I was trying to get the fuel up the lines with the prime pump Duh! and no, asking if the fuel tank had fuel in it was a good question. never know sometime its the easy stuff we forget to look at
Thank you all.
   / 2cyl Perking trying to prime fuel line??? #4
Glad you got it figured out!
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2025 CFG Industrial QK16R (A50123)
2025 CFG...
2025 Forklift Safety Man Basket (A51691)
2025 Forklift...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
