2910i Coolant
   / 2910i Coolant #1
DeeDubya
San Marcos, TX
Branson 2910i
The owner's manual says to change the coolant and add corrosion inhibitor every year but doesn't way what kind. It's green so I assume it's the old type, adequate for cast iron blocks. Any suggestions on corrosion inhibitor, brand of coolant, etc. would be very helpful. Water pump lubricant?
   / 2910i Coolant #2
Typically, all coolants have some form of corrosion inhibitor, but it would be cavitation damage that I would be concerned about, depending on who you talk to, they could be one and the same, but different.
I just replaced mine with an SCA coolant manufactured by PEAK, it is called Fleet Charge and it is $16 a gallon (100%) at advance auto. There is also Final Charge at NAPA for around $26 a gallon 100% or 50%. Whatever one you choose, get the 100% and dilute with $1 gallon distilled water.
You can use low silicone extended coolant but if you add the SCA's you better be absolutely sure of the type and what % you are adding. The Fleet Charge is a one step fill.
PAIR OF DIAMOND PLATE DOUBLE AXLE FENDERS (A51247)
PAIR OF DIAMOND...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A51692)
2023 Fat Truck...
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
KSI Conveyor (A53473)
