Oil & Fuel 2910 with 3 cylinder diesel
   / 2910 with 3 cylinder diesel #1
MSfarmer
The oil level in the crankcase on my early 80's diesel increases between oil changes. I'm told that this indicates a leaking shaft seal on the injector pump. I've purchased the new seal from my dealer and am ready to tackle the job. Am I headed in the right direction? All tips and info on R & R this pump would be appreciated.
   / 2910 with 3 cylinder diesel #2
Is this a New Holland/Ford or a Kubota model?
Mark
   / 2910 with 3 cylinder diesel #3
Ford had a 3 cyl 2910 from '84-86 then Ford/New Holland from '87-'89.
Mark,
I have a Ford. Mine originally came with the blue stripped decals on the hood. I have since seen some with black decals.
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
New/Unused SD Lanch 12x20 Enclosed Carport (A57454)
New/Unused SD...
