2910 Tiltmeter
/ 2910 Tiltmeter #1
ronjhall
Super Star Member
SW Oakland County Michigan
2, Kubota B2910 HST
Installed Tiltmeter on my 2910 today./w3tcompact/icons/smile.gif Had to take it out and check some of the small slopes on my property. I knew there were a couple of places that had some angle to them./w3tcompact/icons/frown.gif I have always had to use FWD to make it up these slopes. Now I'm concerned with my tilt meter on and others talking about pucker power starting around 15 degrees. I'll have to start taking extra caution on the slopes./w3tcompact/icons/tongue.gif See attached picture.
/ 2910 Tiltmeter #2
That's just about exactly the maximum tilt I've gone with mine, and I parked it there and got off to see how hard it would be to push it on over enough to get the wheels on the high side off the ground. I didnt get them off the ground, but it's still as far as I want to go, personally. Just call me a coward, but I'm uncomfortable at 12-15 degrees, get real cautious at over 15 degrees, and just plain don't intend to intentionally go 20.
Bird
/ 2910 Tiltmeter
Bird
I lived here 29 years. Never had a ROP's or Tiltmeter before. My 2 sons grew up mowing lawn during those years./w3tcompact/icons/smile.gif Never had a problem with rollover. But know I'll watch the grand kids when they are here to give a hand.
/ 2910 Tiltmeter #4
My newly ordered tractor came with a free tiltmeter. I don't know if I'll mount it. I'd be curious to see what it indicates with my old Internatinal. I don't worry so much about tipping over with it, although with no roll bar you would think I should. Rather then feeling like its going to tip it starts sliding down the hill. I would have to estimare the slope is 30 to 35 degrees. I cannot go up it, thats for sure. The Internatinal is a saddle style tractor so its center of gravity is lower. Rat...
/ 2910 Tiltmeter #5
Noticed in the attachment, maybe its the way the picture is taken, but the tilt meter seems to be leaning back , is that the way its made to be mounted?(I am clueless can you tell!haven't got my 2910 yet ... HOPEFULLY this weekend, dealer keeps me wondering) but just checking , I know it will change the angle(angle will read higher than actual)
/ 2910 Tiltmeter
Cornflake
Yes there is a small amount of leaning to front of tractor. I had it installed straight up. It moved front of Tiltmeter to close to steering wheel. I tilted Tiltmeter back a small amount. For clearance, I had tractor on slope when I took picture and when I made adjustment. Ball moved a little further into red. I plan on shortening bracket legs and mount Tiltmeter closer to hood. Since you haven't mounted your Tiltmeter yet you may need to be concerned about mounting Tiltmeter in position I have chosen. When FEL is on tractor, cross brace is just in front of fuel cap. This makes any funnel used to fill fuel tank lay toward dash and now the Tiltmeter. I plan on solving this problem by using a 55-gallon drum and pump to fill tank.
/ 2910 Tiltmeter #7
Hope you didn;t think I was busting on your install!
Looks like harder to read anyhow when straight up/down.
What do you think of the Model 51 tiltmeter? has L/R frontbak
on same.
I also will be looking at getting say a 30 gal barrel and pump
rather than fool with lifting. Haven't got there yet tho.
/ 2910 Tiltmeter
Cornflake
Not a problem. Knew it had to be changed. But like others on TBN, when I get a new piece of equipment/w3tcompact/icons/smile.gif I like to post the results sooner than later./w3tcompact/icons/tongue.gif You have a sharp eye.
/ 2910 Tiltmeter
Cornflake
I like the model 51. Just didn't think that there was a need for it on my tractor. I'm more concerned about sideways than front to back tilt. If it hadn't been for TBN I would not have known about a Tiltmeter./w3tcompact/icons/smile.gif
My next project is installing a toothbar. As soon as UPS delivers it./w3tcompact/icons/tongue.gif
/ 2910 Tiltmeter
Cornflake
I must have a case of CRS this morning. I went out and looked at tractor. The reason for putting Tiltmeter on an angle was I had it mounted to far forward. This interfered with getting gauge portion of dash back into its proper place. I still need to move it back toward hood about 1".
/ 2910 Tiltmeter #11
Hi Guys, Rick here at R&B.
All Tiltmeters are designed to read properly when VERTICAL
only. A slight tilt of 5 degrees forward or backwards is allowed.
Anything more will give a false reading. PLEASE mount any
meter vertically. If the 2 "L" shaped mounting brackets do
not work for you, I have a new style bracket that should.
If ordering, please ask for new style if needed. No extra
charge. Anyone that has "L" shaped brackets that will not
let you mount where you like and still be vertical, let me know.
I will send you a new style. Now, about the #51 dual dial
tiltmeter. Good meter. Dials are too small for practical use on
tractors. Designed for other applications. Not tractors. I have
sold a few to tractor owners, and they seem to like them, but
most say they are too small dials. The best models are
either the 25C, or in few cases, the 7489C. Both work well
on tractors. Both C versions are painted to show caution and
danger points using A.N.S.I standards. Note; these are
standards only. Your applications may vary, due to fel, wheel
weights, filled tires, etc. Thanks Guys. Rick
Rick Hedgecock
R&B Manufacturing
http://www.tiltmeter.com
(816)587-9814
/ 2910 Tiltmeter #12
<font color=blue>best models are either the 25C, or in few cases, the 7489C</font color=blue>
And I have the 25C for side to side and 7489C for front to rear. May or may not really need a front to rear, but I like'em that way./w3tcompact/icons/smile.gif
/ 2910 Tiltmeter
Rick
Thanks for information. I have repositioned my Tiltmeter toward hood about ¾". This allows me to straighten "L" bracket to a vertical position. I used brackets supplied with long leg attached to dash. This allows some movement of brackets and puts Tiltmeter as close to dash as it can be. I needed to get mounting bolts away from gauges to get clearance for mounting bolts. Your have a great product. Thanks for your concern.
/ 2910 Tiltmeter #14
Hey thanks! Here where I live the hills are so steep that I would mostly be going up and down thats why the Model 51 was most appealing , mainly because I could (hopefully) mount it where I could see it rather than off to the side(no canopy yet).
BTW -Tractor should be here Sunday morning. Cant' wait!
/ 2910 Tiltmeter
Cornflake
Tractor delivery on Sunday?/w3tcompact/icons/shocked.gif Where is this dealer located?/w3tcompact/icons/smile.gif My dealer isn't even open on Saturday this time of year./w3tcompact/icons/frown.gif
6x12 Utility Trailer (A62613)
6x12 Utility...
2018 Case 580N EP 4x4 Loader Backhoe (A64553)
2018 Case 580N EP...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
