I spent a couple of hours reading the forums here regarding this and talked to my dealer. A couple of years ago similar issue and the factory rep sent me the new harness and relay kit.
The problem started erraticly where when attempting to start it would lock out on safety. Let it set a few minutes and it would work fine. Now it will only start by jumping the starter motor and disconnecting the lockout solenoid. It then starts fine. When i put the key on all the lights and so on work ok. the charging system is keeping the battery charged and I checked with a volt meter and with the motor running output was over 14 volts.
Glow plugs work fine off the ignition switch. I jump out the brake switch and the seat switch with no success. My dealer faxed me a wiring diagram, but that just shows connections. I need a wiring schematic since i assume somehow the brake safety circuit wires are bad? or loose connection?
I sure would appreciate some advice, thoughts or a source for TNT to blow the thing up. The worst is my neighbor who curses the red beast and beats me up for not spending another $10,000.00 to get a "real tractor you know the ones they paint green" He calls me daily and says "broke down again"
Len
Len
