270DTC filters
   / 270DTC filters #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I know there has been some questions for filter cross references for the various FarmTracs. I own a 270DTC and did a little research to find filters. My engine is the Daedong A139LG. This is what I used to search for filters. Wix does list some other models of FarmTrac but not the 270DTC. Here is what I have found. This is by no means exhaustive of all the filters out there. I found the Wix filters at Parts Plus. They didn't have the oil filter in the store but said they could get it from the warehouse. I said sounds good. I was there at about 4:00 and she asked if I needed the filter tonight or tomorrow. I said it is 90+ outside with high humidity I have not intention of changing the oil in this heat. So tomorrow would be fine. I thought that was great service and will use them again.
I don't remember what I did last time I changed the oil but today I noticed that the 4.75 qts. brought the oil level to just over the low level on the dipstick. I ended up putting just over 6 qts. to bring the level just below the high mark on the dipstick.
I also changed the fuel filter. Not easy with the loader frame there. Now the fuel level in the bowel is about 3/4 full. How do I get the rest of the air out? Will it be okay at this level or will is starve for fuel under heavy load?
Air Filter Fuel Filter Oil Filter
Wix 46449 33507 51324
Fram CA9248 C10517 PH2921
Purelator A35270 F54557 L20253
NAPA 6449 3507 Gold 51324 or
1324
I hope you can read this table. I looks good when editing but noticed it is all bunched up when posted.
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
