2706E 3pt hydraulics not working
   / 2706E 3pt hydraulics not working #1
DirtyJobs
Massey Ferguson 2706E
I have a 2706E that has had an ongoing issue with the 3pt hydraulics.
Today they stopped working, and I'm looking to see if anyone in here what I need to dig into in order to get them operational again.
The FEL and steering work they way they should. There's oil in the site glass. The tractor has 227hrs on it.
Is there any place where I can get a parts manual for this machine?
Thanks.
   / 2706E 3pt hydraulics not working #2
With 227 hrs on it is it still under warrantee? Ask the dealer without necessarily getting into a service call or doing anything. I don't know about the 2706E but my Massey has a separate pump for the 3 pt hitch. No idea what your "ongoing issues" are.
First make sure your draft control lever is in the position to take draft control out of the picture. Usually that is all the way up/back. That leaves the Position lever in control of the 3 pt. It should then go up with hydraulic force and down with gravity or implement weight or pressure from your foot. If that does not work there is some internal 3 pt hitch hydraulic issue. The FEL and steering are unrelated (at least on most Masseys I have worked around) and probably on yours too. Your owners manual should be helpful in sorting this out. You can go through 'Ask AGCO' on the web and get access to a parts manual though I'm not sure that will do any good.
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
Ramfan Gas Powered Ventilator (A56860)
Ramfan Gas Powered...
Mi-T-M 4,000psi Pressure Washer (A56860)
Mi-T-M 4,000psi...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TANK MANIFOLD (A58214)
