Oil & Fuel 2705E Service
   / 2705E Service #1
lovefd1003
Massey Ferguson 2705E
I'm purchasing a repossessed 2705E this week. It has 149 hours on it and I don't think it has ever been serviced. Unfortunately the tractor does not come with the owners manual, and I'm not purchasing it from a Massey dealer. I did locate a manual online and it should be here in a couple of weeks. I would like to hurry up and get it serviced so I can put it to work. Could anybody please advise on filters, and fluid type and quantity? There is very little information about this tractor floating around that I can find. Thanks in advance.
   / 2705E Service #2
I have a 2705E, just go to agcoparts and guest login and search your model
6255329M91 is the shuttle hydraulic filter
7069738M1 is the hydro hydraulic filter
7064608M91 is the oil filter
and checking my dealer invoice the numbers are the same, well for the shuttle transmission anyways. the hydraulic filter was around $105, oil filter was $24 Canadian pesos.
For Hydraulic oil my dealer said use shell spirax s4 txm and any good 0w30 or 10w30 diesel engine oil I used Rotella t5 10w30. Front axle uses the same oil as transmission change at 150 hours
takes 5.8L of engine oil and 38 liters for the transmission and 8.5 liters for the front axle. make sure you get both oil pan drain plugs.
   / 2705E Service
Thank you very much!!
UNUSED FUTURE QUICK ATTACH FLAIL MOWER (A51244)
UNUSED FUTURE...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
1267 (A50490)
1267 (A50490)
Fifth wheel multi use trailer. (A52128)
Fifth wheel multi...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 78"...
