265 blowing main fuse when engaging PTO
   / 265 blowing main fuse when engaging PTO #1
Verticaltrx
Veteran Member
VA
Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I have a JD 265 garden tractor that has started blowing the main fuse when you engage the PTO/mower deck. Trying to get things ready for next mowing season so I need to get to the bottom of this. I already replaced the switch and that didn't have any effect. Is the PTO clutch bad? How would one test that? Other thoughts?
Thanks in advance.
   / 265 blowing main fuse when engaging PTO #2
I think I would start looking a rubbed wires or something. That mower has some age on it and the pto wires could be shorted.
   / 265 blowing main fuse when engaging PTO #3
Start by unplugging the two wire connector at the pto clutch, and then engage the pto switch, and see if it still blows the fuse. If fuse blows, most likely short someplace between the clutch switch, and the clutch.
If the fuse doesn't blow, then most likely clutch is shorted. Sometimes you can take a meter and put one lead on one of the clutch wires, and the other lead on the metal part of the clutch. if you have continuity, you have a short. Most of the time you need to know what the normal resistance of the clutch is between the two wires. If out of spec, then replace. I bet you have a shorted clutch.
Thanks for the replies. I'll give those things a try and report back.
It must be the clutch and not the wiring. I disconnected the plug from the clutch and it didn't blow the fuse. I'll check for continuity between the clutch wires and housing next, but regardless it looks like a new clutch is in order. While I was under there I noticed the main drive belt for the transmission was about shot, so that's on the list too.
   / 265 blowing main fuse when engaging PTO #6
I'm not sure if our clutches are the same, but the one on my f910 was blowing the fuse and I found the metal tab that holds the coil part of the clutch had snapped at the weld, so when it engaged the rest of the clutch spun around until the wires hit the tab and shorted out. I guess the previous owner had tightened the bolt that holds the tab to the motor, the slight wobble worked on it until it snapped off.
Jim
   / 265 blowing main fuse when engaging PTO #7
Essentially the clutch coil is one big electromagnet.
That means that you have a pos and neg connection to make the circuit work. Somewhere the pos is shorting to ground.
Look for chaffed wire where they enter the coil area. I would doubt if a short would be internal but most probably where they exit. Once you find the chaffed wire, slip some plastic tubing over the damaged insulation or again you could isolate with a hot glue gun once the damaged area is de-greased.
Sure sounds repairable to me.
   / 265 blowing main fuse when engaging PTO #8
I have seen the connection wires get shorted out, and I have seen the coil pack short out and cause problems. Actually I have seen the coil packs burnt, and brittle. I no external wire damage, I wojld bet that the coil pack is shorted internally.
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
JLG 1255 Telehandler (A55218)
JLG 1255...
2014 Ford Transit Connect Cargo Van (A55852)
2014 Ford Transit...
UNUSED RAYTREE RMVR76 - 76" HYD VIBRATORY ROLLER (A54757)
UNUSED RAYTREE...
