2635 Update
   / 2635 Update #1
SDT
Veteran Member
SE Indiana
Multiple Fords and Kubotas
Not good news, folks.
Today, I took the 2635 and Woods BB840X 7' mower out to tackle one of my tougher mowing jobs. The tractor had about 21 hours on it when I started. I had previously used it only for a couple of less demanding mowing jobs on flat ground with no obstacles and much lighter cover, so today was the suitability test.
Heavy grass and lots of obstacles but previously well cut in with my MF 533 and 6' BB720X.
The 2635 is new, purchased late last fall, and used little until needed (NOW!), so some familiarization with the tractor and mower is in order in this steep and heavily obstacled ground. After an hour or so I was becoming proficient with the synchro shuttle transmission, steering, FWD, 7' cutter, etc., and begining to think that the 2635 could save considerable time vis a vis the unsynchronized 2WD 533 and 6' cutter, which, of course, is why I bought it.
Then the roof fell in. Being both engineer and a mechanic, I pay close attention to instruments, sounds, performance, etc., and had been well pleased with the tractors performance so far. RPMs had dropped only slightly from governed speed when hitting tough spots and I was gaining confidence in the 2635, which I had bought with trepidation (It does spec out very well vis a vis the Kubota and NH competition against which I compared it.).
Upon making a turn in a heavy spot, I noticed that the RPMs dropped significantly, and was a bit surprised. Within a minute or so, the engine lost power such that it was impossible to pull the mower regardless of the cover. Neither hand nor foot throttle setting made much difference. I lifted the mower and headed for the shop.
As it was uphill to the shop and the engine had lost nearly all power. I continued to gear down hoping to be able to get it back inside before it shut down completely. Eventually, I was down to low range 1st gear but I did make it. The engine would not REV beyond about 1000 RPMs unloaded. There was no black smoke from the exhaust but I did notice white smoke upon occassion (turbo oil seal?)
I'm **** and do not put my equipment into the barn before proper clean up so, since it was still running, I decided to do my regular compressed air blow down, mower lubrication, etc., before putting it away. I decided to let the engine idle because I was not sure if it would restart if I shut it down.
After clean up, upon moving the 2635 into the barn, I noticed that the engine would now REV to governed speed without smoke, and power (unloaded) seemed normal. Not wishing to tempt fate, I put it in the barn and finished up with the 533, which, of course, took longer than it would have had I been able to use the 2635 (THIS IS WHY I BOUGHT IT.)
Not sure what is wrong but if the tractor was not new I would suspect fuel filters, turbo charger, injection pump, and air filter(s), in that order. Since it is new, I'm guessing a turbo charger seal/bearing or an injection pump issue. There are no computer controlled systems on this tractor, which is another important reason why I bought it.
Thoughts?
In any event, it's MFs problem, though my inconvenience. I will call my dealer Monday.
This is MFs second chance. I've also had problems with the 533, bought new in 2007.
If issues with the 2635 continue until warranty expiration is imminent (BTDT with the 533, and subsequently resolved most if the issues myself.), I will sell both 2635 and 533 and buy one or two Kubotas. Folks do not have issues with Kubotas.
SDT
   / 2635 Update #2
Could it be a stick or wad of cut grass that was preventing full movement of the throttle linkage that you subsequently removed during the cleaning ritual?
I'd see how it does with the cutter, tomorrow. Good luck - got my fingers crossed XX.
   / 2635 Update
No.
I've been doing this for decades, folks.
Dean
   / 2635 Update #4
Sounds like fuel filters to me. Usually when there's occasional white smoke and poor performance that's what I find. I would vote against turbo and injection pump as my experience has been when they go they don't come back. I'm interested in hearing what it is.
   / 2635 Update
Could be.
The tractor has only 23 hours on it but who knows what was done at the factory or while it sat on the dealers lot for several months. It had 13 hours on it when delivered.
I will post back once I know more.
SDT
   / 2635 Update
Apologizies to Baby Grand.
I was in a grouchy mood yesterday but that does not excuse terse replies to folks attempting to help.
SDT
   / 2635 Update
I was finally able to get my MF dealer to pick up the 2635 today but the mechanic told me that he will probably not be able to work on it until tomorrow.
The immediate plan is to open the fuel filter drains to see what comes out. If all looks good they will pull it on the dyno for an hour or so to see what happens.
More to follow.
SDT
   / 2635 Update
More to follow.
SDT
Dealer called this morning.
It seems that the electrical connections at the fuel pump were loose and pump operation was intermittent. Installation of internal star washers (which should have been OEM equipment) and retightening appears to have solved the problem.
According to the dealer, this is a known issue with this model. If so, one wonders why it was not checked/rectified upon pre delivery inspection.
Tractor should be back tomorrow. I will give it a workout over the weekend.
SDT
   / 2635 Update
SDT
I used the 2635 today to mow for about two hours. The fuel issue appears to have been corrected. I worked it hard and all seems well.
Upon clean up afterfinishing I noticed that the bleeder on the secondary fuel filter was dripping. Tightening it a bit appears to have stopped it.
It looks like the next issue is going to be the solenoid/starter.
It took several start attempts to get the engine to crank. Each turn of the key resulted in a heavy thunk as the solenoid pulled in but the starter did not turn. It eventually started on the fourth attempt. I did not shut down the engine until I was finished, everything was serviced and back in the barn. It did start when I tried it after putting it away. I'll check the connections tomorrow. If it happens again, I'll have the dealer change the solenoid and inspect the starter.
SDT
2002 International 9200i Truck (A51039)
2002 International...
2000 PETERBILT 357 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2015 Isuzu Sewer Jetter Truck (A49461)
2015 Isuzu Sewer...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2000 Ford F150 (A49461)
2000 Ford F150...
