2615 radiator drain and filters
   / 2615 radiator drain and filters #1
BamaRob
Platinum Member
Alabama
Mahindra 2615 4WD
A word of caution to 2615 owners (may apply to all 15 series?)... The little plastic valve for draining your radiator is vulnerable to damage from brush. Ask me how I know... :D I have to try to locate a replacement today. While I'm at it, I'd like to get a replacement air and fuel filters. Does anyone have part numbers handy for these items?
Thanks,
BR
   / 2615 radiator drain and filters #2
Rob,
I believe the water cock parts you will need are part #'s 1170415000 joint, and 67401A00113 cock assy. The air filter is part# 35530501800 and the fuel filter is # MM404879. I hope this helps.
   / 2615 radiator drain and filters #3
Yes, I know of what you speak!
I replaced mine with a nylon straight tubing splice/connector and never looked back. My Mahindra dealer is about 2 hours away so I found my solution at TSC (10 minutes away) for less than a buck. A couple of zip ties keeps everything up and out of the way.
Lawall,
Thanks for the part numbers. I'm hoping for cross reference numbers to Fram/Wicks/etc. so, hopefully, I can find them locally. I try to support my Mahindra dealer's parts department, but for regular maintenance items like filters and fluids, it's much more convenient to get them from local parts suppliers.
H3hound,
I'm going with something similar on the drain cock. I picked up a straight nylon splice/connector at the parts store and will be tying it up and out of harms way (for the most part) with zip ties.
Thanks,
BR
   / 2615 radiator drain and filters #5
Rob,
Galen missed a number on his list. The water joint unit is 1174 0415 000 (not 1170415000). Air and fuel numbers are correct. If you find you want to use factory parts the plastic plug that goes into the water joint is #67401-00113
George
UNUSED AGT QNT30 EXCAVATOR (A51243)
UNUSED AGT QNT30...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2007 CATERPILLAR 930G WHEEL LOADER (A51242)
2007 CATERPILLAR...
2015 CATERPILLAR TL1055C TELESCOPIC FORKLIFT (A51242)
2015 CATERPILLAR...
