2615 air filter
/ 2615 air filter #1
SABULA FARMER
Pennsylvania
Bobcat CT335SST
I did a search on the air filter for the 2615 and found that there are kubota and Baldwin filters that folks talked about....Is there anyone actually using them? If so how was the fit and did they seal properly?
Thanks.
S.F.
/ 2615 air filter #2
I put the Kubota in mine, and it fit fine. That was a couple of years back. They may have changed some since then, I don't know. Best thing to do is take your old filter with you when replacing it.
/ 2615 air filter #3
Someone posted here a while back a list of WIX filters for various Mahindra models. The list showed the following for a 2615.
Fuel 33264
Air 46483
Hyd. 57118
HST 51663
Lube 51356
I have not bought these WIX filters for mine yet and cannot verify the list is correct.
/ 2615 air filter
..Ok thanks fellas. I put the Baldwin in mine..It was a little longer than the stock filter, but I think it was from the rubber seals at both ends. I had to tweak down the wing nut pretty good but all seems well.
/ 2615 air filter #5
I just purchased the WIX Air filter for mine and ran into the same problem as Sabula. It was about 1/4" longer but was due to the different type of seal at each end. I bought the tractor used and have only had it for 4 days so I was afraid to tweak down on it. How has the baldwin performed overtime? Am I safe to make it fit?
/ 2615 air filter
Yes, I had mine in for a few months, was still in it when I traded the tractor in... It worked well.
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2001 Peterbilt 378 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2001 Peterbilt 378...
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
