2610d clutch
   / 2610d clutch #1
gsaff
Last time I had my 2610 out (3 weeks or so ago) it was hard shifting the main transmission as if the clutch were not working properly. I finished mowing and managed to back it into the barn. Went out yesterday and started it but it will not move. I can run through the gears while it sits running but when I release the clutch pedal- nothing happens. Not even a grunt or slight catch. Is the clutch shot or just stuck? Can't run it up against anything since it won't move. Hours show 376 on the meter. Any help is most appreciated.
   / 2610d clutch #2
Will the mower work properly now? If so it is likely in the powershift unit/hydraulic problem. If the mower wont spin now it is probably a clutch/pressure plate, or a splined coupler.
Aaron
Parts@HoyeTractor.com
(940)438-0386
   / 2610d clutch
Aaron,
I unhooked the implements before I backed it in to the barn. There's nothing on it right now.
   / 2610d clutch
Aaron,
The PTO shifts in and the shaft spins but I did notice while running it (stationary of course) that the front end loader was struggling a bit going up. Excuse my ignorance but... Powershift/Hydraulic Unit is ?????
   / 2610d clutch #5
The hydraulics for the loader are separate from the powershift hydraulics. I dont think the two are related unless you are very low on HYD oil. I dont think that it is a stuck clutch either as that would not stop moving- as in through the garage door - another story. Your tractor just wont move at all. Check you hydraulic oil and then, if full, you will need to hook up the mower (if possible) to put a load on the PTO to see if it still spins. This will help tell you where the power is disconnected.
Aaron
(940)438-0386
   / 2610d clutch
Drained the tranny and pulled the filter. It was totally clogged. After a cleaning and new fluid- it runs like a top. Thanks to Evan at Hoye for the input!
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
UNUSED RAYTREE RABC44-44" ARTICULATING BRUSH CUTTE (A51248)
UNUSED RAYTREE...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
2019 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2019 KOMATSU...
