2610 H
   / 2610 H #1
Moak
Bronze Member
Greenfield Center
Massey Ferguson 3165 Bronson 2610H
What services need to be done at the 100-hour mark. I reached out to my dealer but he's not getting back to me.
   / 2610 H #2
Tractors usually don't require much to be done at 100 hours.
Just the basic stuff, greasing, check bolts, check fluids, clean the air filters, lube the linkages and pivot points on the control levers with whatever spray lube you like the most, check tire pressures, things like that.
   / 2610 H
Ok, that sorta what I thought but it never hurts to ask. The stuff you mentioned is done regularly Nuts and bolts I check at every 25 hours don't take long and better safe than sorry.
Thank you
   / 2610 H
I'm sure they are and if I had one to look at, I probably wouldn't have to ask.
   / 2610 H
I'll look and see. Thank You.
   / 2610 H #9
I would suspect engine oil at 100 hrs.
   / 2610 H #10
at 100 hours should only be your engine oil + filter, other than greasing he zerks that should be all that required to service at this interval
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2009 INTERNATIONAL PRO STAR (A52472)
2009 INTERNATIONAL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
