2605H Starter Clicks but Does Not Turnover
/ 2605H Starter Clicks but Does Not Turnover #1
db32066
Massey Ferguson 2605H
I have a 2605H that I bought in 2020. For a while it would click one time when I would turn the key, after several turns of the key it finally turn over. Recently, it has gotten worse. I have tested the battery and jumped it but it still can take several (up to 50) turns of the ignition for it to turn over.
I have also jumped the solenoid and it still clicks.
Should I change the solenoid? Or just strait to the starter? Any suggestions would be helpful!
/ 2605H Starter Clicks but Does Not Turnover #2
It's the solenoid; if it comes apart you can carefully tap out the square head copper bolts that the battery cables attach to and clean everything up on a wire wheel, then install them so the uneroded part of the heads are facing inward. Had the very same issue on my forklift and that fixed it right up.
/ 2605H Starter Clicks but Does Not Turnover #3
You may want to check (no, disassemble and wire brush) all 4 of your battery cable connections first.
Sometimes, amperage can jump across a bad connection.
Another sign is to turn on the lights, then hit the starter. If the lights go out, probably a bad connection. If the lights remain bright, go for the solenoid as described above.
1991 25ft Wellcraft 250 Sportsman Boat with 1980 27ft Float-On T/A Boat Trailer. (A61574)
1991 25ft...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2013 Ford Focus Sedan (A61574)
2013 Ford Focus...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
