2538B backhoe fit any other models
   / 2538B backhoe fit any other models #1
dwalk19
Addison, ny
2018 LS XG3140H TLB
Does anyone know if a mahindra 2538B backhoe would fit any other model besides the 2538, that would be close in HP, maybe a 40 hp, or 36hp, seems like they all have their own backhoes
   / 2538B backhoe fit any other models #2
The BH is an American Made product but I don’t recall the name. Someone will chime in.
The problem with the add-on BH is the frame- those will need to be model specific.
The reason i'm asking is I found a good shape/priced subframe backhoe (mahindra 2538B) and was thinking of buying it and upgrading my tractor to a 2538 if i can find a reasonably priced one, or was wondering if that particular backhoe would fit their other model tractors maybe with a different subframe though
   / 2538B backhoe fit any other models #4
I wish I knew the BH manufactures name. They could tell you for sure- plus they may have different sub frames that work on that BH. Someone will know. Or do a search here- I know I’ve seen it.
   / 2538B backhoe fit any other models #5
Probably Kansas Machine Works. They made my BH and loder. However the subframe will likely not work for any other make or model as it frame specific.
   / 2538B backhoe fit any other models #6
I have a 2538 with a backhoe and the manufacture is KMW out of Sterling, KS.
   / 2538B backhoe fit any other models #7
Will the 2538 fit on my mohindra 2645 tractor?
   / 2538B backhoe fit any other models #8
I think once you get above 40 hp, the frame changes somewhat.
It should fit on a 2540, 0r 2638, or 2640.
Go on the Mahindra usa website and "build one" to see if it's the same BH model.
2015 Nissan Altima Sedan (A50324)
2015 Nissan Altima...
2007 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2007 Ford F-150...
Scag 36 Advantage Push Mower (A50121)
Scag 36 Advantage...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
John Deere 5075E (A50120)
John Deere 5075E...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
