2520
   / 2520 #1
fitzisprint955
Bronze Member
Barneveld. Wisconsin
2305/345GX
Anyone that has a 2520 or the previous version of the 2520 can you help? Is it a problem having the final drives the way they are? On my 2305 the rear axle is straight, is the weight of a backhoe going to be a problem on the 2520? And is the engine/trans being a stressed member of the frame a problem? The 2305 has a complete frame around it, seems really sturdy? Thanks for any advice! Fitz /forums/images/graemlins/confused.gif
   / 2520 #2
Fitz,
The 2520 IS made to go along with the 46 backhoe. If you're serious, why don't you go and check one out?
   / 2520 #3
Consider this: most older tractors don't have central frames that go along beside the engine. Of course, most of those weren't designed to work with a backhoe.
Ralph
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
Yale MPB040-EN24T2748 4,000lbs Electric Walk-Behind Pallet Jack (A51691)
Yale...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51692)
Heil V-1722 28Yd...
DITCH WITCH FX30 VACUUM TRAILER (A51406)
DITCH WITCH FX30...
