Rotary Cutter 251Bush Hog question
   / 251Bush Hog question #1
Paw Paw G
86 Zetor 6211
Does anyone know how to level the deck on a 2510 Bush Hog? I know there is a leveling rod that attaches the front and rear with a jam nut and turnbuckle on each end of the rod, but I can't see anyway to turn it without removing the pin in either end which will allow the front yoke to drop. Looks kind of dangerous to me.
   / 251Bush Hog question #3
It sounds like you loosen both jamb nuts and then turn the rod that is between the two yokes. Then tighten the jamb nuts when desired pitch/level is obtained.
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
2014 Dodge Charger (A50324)
2014 Dodge Charger...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51243)
UNUSED X-STAR 101"...
TEST YOUR BID BUTTON! (A51243)
TEST YOUR BID...
2024 KRUZ Ravens Tri Axle Dump Trailer (A47384)
2024 KRUZ Ravens...
John Deere 455G Loader (A48837)
John Deere 455G...
