250 gallon propane tanks, used OK?
   / 250 gallon propane tanks, used OK? #1
rich_ncal
Northern California
TS1610
I am thinking of buying a propane tank instead of leasing. I have found a 250 gallon propane tank built in 1991 that the seller says is form a foreclosed home. Is there any reason not to buy a 1991 propane tank?
The seller has a friend from a propane company that will install the tank. Other than cleaning and a little paint, what other upkeep costs are there be for an 18 year old tank?
   / 250 gallon propane tanks, used OK? #2
Propane Co. will probably need to pressure test the tank. I know they do on anything smaller. And may even check to make sure seller is the owner and not a stolen tank. I don't know what you are paying for this tank but have you priced a new one.
   / 250 gallon propane tanks, used OK? #3
Good Evenin Rich,
I bought a 330 gal a dew years back for my Vt residence, and it was 20 years old then. No problems, as George stated, the propane company will pressure test the tank as routine maintainance anyway !
Mine was half full when I bought it from the farmer up the road. and i think I payed $400 for the whole thing, plus between the both of us, we did the install.
   / 250 gallon propane tanks, used OK? #4
I would check with your propane supplier to see what they require before they'll fill it.
You might want to check for any company labels and serial nos. on it to try to make sure it isn't a leased tank and that it is an owner tank. If you can find a company name on it to call with the serial no., that is the information you would need.
   / 250 gallon propane tanks, used OK? #5
I've got one that came with the house and I'm sure it's at least 25-30 years old. No problems to date. Propane company didn't even question it. Just came and filled it. Of course our delivery driver is pretty down to earth. I'm sure there were things he looked for when he first came out but didn't mention and I didn't ask.
Jay
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
UNUSED IRANCH EXCAVATOR ATTACHMENT SET (A54757)
UNUSED IRANCH...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
