25 series common transmission/differential sump?
   / 25 series common transmission/differential sump? #1
vhacmoduprej
Columbia, MO
E350-DI
Does the 3325/3525 have a common sump for transmission and differential? I'm assuming both drains are for the same reservoir? (no service manual yet)
   / 25 series common transmission/differential sump? #2
I have a 3525, and a service manual. Yes, the trans and differential share lubricant. Both plugs drain the same housing, one in front and one in rear. Oil specs call for API GL-4, and specifically warns against using GL-5 as the transmission has copper based alloy components which can be corroded by GL-5.
Bob
2023 JOHN DEERE 135G EXCAVATOR (A51242)
2023 JOHN DEERE...
20' Sea Container (A50774)
20' Sea Container...
POWER CORD W/ REEL, 12G WIRE, VICE (A51244)
POWER CORD W/...
New 4-235/85R16 Roadguider Trailer Tires (A50774)
New 4-235/85R16...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
(4) 16' Tarter Corral Panels (A50515)
(4) 16' Tarter...
