25 Hours.(Tire Choice)
   / 25 Hours.(Tire Choice) #1
banjobj
Southern York County, ME
TC 21D
I have just passed 25 hours on my TC 21 D and I still am very happy with it. To add my two cents to the best tire for your tractor discussion, If I had it to do over again I would have gotten the Ags. The R-4s just don't make it in the GOO!!!!!!
   / 25 Hours.(Tire Choice) #2
Banjobj,
Glad you're enjoying your new machine. I guess it all depends on what you are doing. I have heavily loaded R4s (600lbs liquid plus 150lbs of wheel weights per wheel). Generally I have plenty of traction! Are you pulling (or pushing) anything that requires extra traction or is this just general getting around? With so few hours, would it be costly to get the ags now?
Peter
   / 25 Hours.(Tire Choice) #3
Banjobj, your right, thats the facts Jack, well almost. R4's work really well on asphalt, concrete, marble, granite, tile floors etc. Problem is only a few of us typically bring the tractor in the house with the possible exceptions of McChalkey and Harv. I like R4's for mowing because they cut up the ground less. But for general getting in the dirt and moving stuff around, its going to be tuff to beat the R1's or AGs. EXCEPT, BUT, if you have the beautiful new lineup of R4's now available at your local Michelin tractor tire dealer. Just check out the R4's the little fat man makes. XM27's will do what you need in a R4 and then some. Will they have my size you might ask, well go to the Michelin website and use the tire selector and it will help you find out or Call, call, call now to find the dealer nearest you. Rat...
P.S. Somewhere somebody has the address on this site, its not just Michelin.com, I think "ags" is involved in the name somewhere. I have it on my other computer.
Double P.S. The above member at TBN is in no way affiliated with or endorsing Michelin tires. Should you ever buy new tires for your tractor that are not Michelins, you are silly.
   / 25 Hours.(Tire Choice) #4
banjobi; i like the r4s, for most of my applications they are the best, will admit that at times i wish i had ags on it, but u always will need what u don't have. rat thinks u are right. HARV sleeps with his tractor/w3tcompact/icons/smile.gif but what the heck , so do I.
I have loaded rear tires but will try adding more rear weight to the 3 PT hitch. I admit the R-4 tires are easier on the lawn but I don't plan on using my tractor to mow. Of course things change and my Craftman mower can't last for ever.
2013 Dodge Journey SUV (A50324)
2013 Dodge Journey...
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
Diesel Forklift (A51691)
Diesel Forklift...
CATERPILLAR 308CR EXCAVATOR (A51242)
CATERPILLAR 308CR...
