2440QT Bush Hog FEL to JD Pin Type
   / 2440QT Bush Hog FEL to JD Pin Type #1
Stever00
Vinemont,Al 35179
New Holland 3930 w/Bushhog loader, Yanmar 2500, Dixie Chopper SilverEagle
Has anyone changed their pin on Bush Hog bucket to John Deere pin on type? I was studying getting on of those Titan weld on plates with top hooks and pins. This loader is wider than a John Deere where its suppose to connect. I'm afraid my loader brackets when I redo them will be in the way of the bottom pins. Just curious if anyone here has went this route? Seems like it would work and be cheaper than going skid steer adapter.
   / 2440QT Bush Hog FEL to JD Pin Type #2
Cheaper isn't always better. Do you already have JD pin type attachments?
Compare the availability of JD pin type attachments to skid steer attachments.
I found and bought a SSQA stump bucket on craigslist before I had a machine that it would fit on, but I knew whatever I got would have SSQA.
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2012 FREIGHTLINER CASCADIA (A52472)
2012 FREIGHTLINER...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2014 FORD F-150 (A52472)
2014 FORD F-150...
