Comparison 240D yanmar rims and tires
   / 240D yanmar rims and tires #1
Slopster
Big island Hi
Yarmar 240D
My first tractor 240D verified serial us import my first question I need rear rims 12.2-24 the best option for replacement it seems as aftermarket or fab aren't out there .
   / 240D yanmar rims and tires #3
The 240D parts manual does not show 12.3-24. Shows several options, but not that one. Normal W9x24W, 194241-34650
  • YM240Parts.pdf
   / 240D yanmar rims and tires #4
Where are you located and how soon do you need them. I have a set that I could sell but I won't be home (southern ilinois) until mid July.
Dave
Being a four wheel drive the specs I see are 12./24 for rear tire so I'm assuming the rim would be matching
Being a four wheel drive the specs I see are 12.2/24 for rear tire so I'm assuming the rim would be matching page 13 under tires it says 12.2/10-24 is that 10 to 12.2 width an 24 height on the rim
I'm in Hawaii on big isle and trying to figure out best option
   / 240D yanmar rims and tires #8
On Hawaii it's going to be expensive no matter what. May be cheapest to buy a set of Kubota ris like California says and of they fit great if not have some custom centers cut and welded in to whatever the cheapest rI'm you can find. Other wise you can buy ym2000 or ym240 rims from Hoye and ship them. Import stuff would probably kill buying from Japan even through there right there.
As for the rim size the tire is basically 9 x 24. It's a 24 inch diameter rim and the tire is 9 inches wide so that tire would not go on a 12 inch wide rim normally it probably would be something like 8 to 9 inches wide itself.
But don't so much worry about rim size width un less your trying to fit tires you currently have.
thanks I'm going to do some welding unless a match for this rim comes up ,tractoring to ya
   / 240D yanmar rims and tires #10
My 276D came with 11.2 X 24 rear tires. I think they are OEM, but not sure. I would be surprised that your smaller tractor came with bigger tires.
I replaced my rims with Deere P/N CH10975 (9 X 24 Use with 11.2 x 24 tire.)
They will bolt up to the 4 bolt centers. They are available, I just purchased one last fall.
I have another Deere P/N M801801 (10 X 24. use with 12 x 24 tire) I know nothing about that number. Do your research
1267 (A50490)
1267 (A50490)
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
2012 Chevrolet Cruz Sedan (A50324)
2012 Chevrolet...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
2012 Bobcat 60" Skidloader Sweeper (A50774)
2012 Bobcat 60"...
