2400H block heater
   / 2400H block heater #1
oldnslo
Super Member
Northern, IL
Branson 2400H, JD X540
My Kats 11407 block heater has failed for the second time in 7 years of ownership approx 650 hrs on the clock. Is anyone else experiencing these failures? First unit solder joint failed on one of the pins. This unit heating element must have burnt out since get infinite ohms across the pins.
Will look closer at water jacket depth surrounding this element when install the new one to see if heating element is close to block at some point and could cause a hot spot.
   / 2400H block heater #2
I lost one at 2 years of service.
I've been told not to run the engine with the heater plugged in. Not sure if it's hogwash or not, but I stopped doing it after the second one was put in.
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A45679)
2018 INTERNATIONAL...
2019 INTERNATIONAL LT625 SLEEPER TRUCK (A50046)
2019 INTERNATIONAL...
2009 TROXELL KILL TRAILER (A48992)
2009 TROXELL KILL...
ASSET DESCRIPTIONS & CONDITION (A50505)
ASSET DESCRIPTIONS...
2022 Gulf Stream Kingsport 248BH Travel Trailer (A48082)
2022 Gulf Stream...
Cat TH407C Telehandler (A50397)
Cat TH407C...
