6sunset6
Veteran Member
- Joined
- May 6, 2007
- Messages
- 1,057
- Location
- SE NY
- Tractor
- NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
This is the loader on a TC34DA. 300hr 7 years old. Curl droops I found loose bolts in the joystick attach ,that seemed to fix it a bit. in fact with only forks on it ,it does not droop at all. With a load on it probably a minute to hit the ground when 2 feet up and level. I followed Jinman's advise. Disconnect the curl QD's and with the bucket edge down dragged it backwards Held steady. I am going to try one more thing to point at the cylinders QD disconnected with a load 2 feet up see if it droops. Whoa droops seems to be in the cylinders Don't know why inman's test did not show it. I probably did it wrong. Better the cylinder than the valve which looks like it cannot be repaired anyway.
