24 gpm pump
   / 24 gpm pump #1
B414IH
erie pa
1964 IH B414
I have a 24 gpm single stage pump. Can I use this for a log splitter? I have a twin B&S 18 HP engine
   / 24 gpm pump #2
To pump 24 GPM using a single stage pump at 3000 psi, will take about 49 HP.
However, you can run that pump with whatever engine you have until it runs out of HP.
As soon as you get the resistance to cause the pressure to go to 3000, psi, at that point you will need 49 HP.
The pressure that will stall your 24 GPM pump using 18 HP is about 1100 psi.
CATERPILLAR CB24B SMOOTH DBL DRUM ROLhttps (A52705)
CATERPILLAR CB24B...
2239 (A51244)
2239 (A51244)
2012 Ford F550 Service Truck (A52377)
2012 Ford F550...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
2013 Caterpillar AP500E Asphalt Paver (A52377)
2013 Caterpillar...
