2350
/ 2350 #1
Piedmont
NC, USA
JD 2520
I was told I either need a ballast box or suite case waeights for a 2350 does anyone have a recomendation?
/ 2350 #2
If you are using your loader, you need ballast weight on the 3 pt. A ballast box or implement will work here. If you are using an implement on the rear, you need the weight of the loader or suitcase weights on the front end to properly counterweight the tractor.
Lewis
/ 2350 #4
If your going to have a front end loader, you can have most any dealer "load" the tires (with a liquid, usually either beet juice or calcium chloride) that adds enough weight to the rear so you don't need to hook up a ballast box. This is ideal if you are using a rear blade or other attachment along with the FEL. Tire loading is also cheaper, or was in my case. I have beet juice-loaded tires on my 2350. Take care - Ben
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
John Deere 8330 (A64126)
John Deere 8330...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A63688)
Magnolia Trailer...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
