2320 worklights
/ 2320 worklights #1
scrappy isb67
princeton nc.
JD 2320
Since I bought the tractor, it has been lacking in the light dept. I have been searching all over fo a light that is small enough to fit but put out enough light. I finall found a set of Hella Optilux 1400 series lights that fit the bill.
Here is a link to some specs:
Optilux Auxiliary Lights
I wired them using the relay in the kit, they get power from a 12ga wire that I ran to the starter. I chose 12ga wire so I could run 2 sets of these lights and maybe some other accessories from it. I powered the control side of the relay from the factory JD worklight harness thru a switch. This way I can turn on/shut all lights down with the factory light switch and can select from the factory hood lights, fwd facing ROPS lights and/or the rear ROPS lights.
I mounted the lights on the JD warnig light brushguards. So far I only have the rear lights installed but am going to pick up another set for the front-facing.
Here are a couple pics of how I mounted them:
I mounted the brush guards upside down and mounted the rear facing lights to the bottom side using the holes in the brushguards. I will drill another set of holes in the topside to mount the fwd lights.
Here is the current switch/ relay setup:
The switch is the one that is included in the kit with the foglights and are temporary, I am planning to find an OEM JD 3 position switch off another machine and install into the plastic panel on the left fender.
and here are a couple pics of the lights in action:
I also plan on retrofitting a set of LED bulbs into these lights so my 20 Amp alternator can keep up.
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2025 Swict 72in Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
Hr:1033.8 (A61572)
Hr:1033.8 (A61572)
