2320 and front/rear aux lights
   / 2320 and front/rear aux lights #12
GeaugaDeere said:
I have the 2 forward facing lights, and one rear facing light. They all work off of the headlight switch, so it's all or nothing. Not being much of a mechanic and being limited on time, I chose to keep it simple and just follow the directions. I believe that BloomingtonMike has done some custom wiring jobs, I suggest contacting him for advice if you wish to do anything outside of the standard install.
The standard was pretty simple, just plug and go basically. One of the trickiest elements was getting the plugs and wires fished down through the small hole at the bottom of the ROPS. Make sure you've got some twist ties to put things back up out of the way when your done.
do you have the part numbers for the lights and required parts for the 2305?
White Metal Roof Panels (A55758)
White Metal Roof...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2021 Ford F-350XL (A53314)
2021 Ford F-350XL...
2016 Chevrolet Caprice Sedan (A55758)
2016 Chevrolet...
2001 International 4700 Bucket Truck, VIN # 1HTSCABNX1H380565 (A54865)
2001 International...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
