2310 tlb
/ 2310 tlb #1
DougM
Northeast Ohio
GC 2310
Well I took the back hoe off of it last night and what was 10 min. turned into about 2 hrs..
So I said this can not be right so I took off the front end loader and about 1 1/2 latter it was off.
Them I put the MMM on and what a night mare......
4 hours total time for all of this I was Hot and soaked What a good time (NOT)...
So now to day to mow for the first time with it,,,
DougM
/ 2310 tlb #2
I take it you didn't bother to read through the instructions on the removals? It only took me 10 minutes the first time I unhooked the FEL, 2nd time, it was under 5 minutes.
BTW, you really only need the instructions once for the FEL & MMM, maybe 2 or 3 times for the backhoe, & after that, you can do it yourself. All the brands seem to have the same basic attachment designs. I hope you were just having a bad attachment day. /forums/images/graemlins/grin.gif
/ 2310 tlb
Yes I did read and re read and had the book with me when I tryed to disconnect every thing...
Like any thing else practice i guess..
now to re place it all
Doug M
/ 2310 tlb #4
Well, some will argue that reading the instructions causes nothing but problems, so maybe you got some bad instructions.
It'll get easier as you get familiar with everything, and learn what positions to set everything in and all. I'd think the backhoe will always be the most difficult attachment to remove, but you should be able to get the FEL and mower on and off in under 5 minutes after 1 or 2 more attempts. /forums/images/graemlins/cool.gif
/ 2310 tlb
Well I just came in from replacing the front end loader..
That took 5 min.
I just hope the back hoe is so easy...
DougM /forums/images/graemlins/smirk.gif
/ 2310 tlb #6
I don't know about the backhoe, since I don't have one yet on my 2300, but the FEL and MMM shouldn't take more than 5 minutes. I made some ramps to go over the MMM so I just "run over it " instead of trying to slide it in and out. Also I usually leave the MMM's drive shaft connected until I back away because it is a little easier to get at once the mower and lift arms are out of the way.
And no I didn't read the instructions. The dealer showed me how to handle the FEL and I worked it out on my own with the MMM.
Besides my Daddy always said "If all else fails, read the instructions". /forums/images/graemlins/wink.gif
/ 2310 tlb #7
That is the easiest way!! Back off and drive on!! My Dads Ford LGT 165 lawnmower deck has a similar set up too that. all pulley are countersunk into the deck, and there are little ramp type brackets on either side of the deck! It is a breeze!!
/ 2310 tlb
The Back hoe is back on took about 20 min had to use a bar to help re aline to brackets.. the tilt is the trick..
I had to disconnect one of the fitings as I could not get it to snap shut would not release took it apart the connected it then re screwed it back on all is well............
My be next time it will go a little better...
DougM
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2013 Chevrolet Traverse SUV (A61574)
2013 Chevrolet...
3097 (A63117)
3097 (A63117)
