2305 w/ 47" front blower performance?
/ 2305 w/ 47" front blower performance? #1
Ironhand
Bronze Member
VT
We got our first significant snow of the winter last night, finally giving me the chance to blow with my new setup. I found myself a little underwhelmed with the throwing distance, though... We had 12-14" of light/sticky snow. I was running at ~3000rpm, low range, cutting about 3/4 the width if the blower and going as fast as I could without any snow spilling over the sides of the blower. Maybe a slow walking pace. The blower was throwing the snow about 20 feet. Normal? Everything is new and seems to be working properly, no broken shear pins, etc.
/ 2305 w/ 47" front blower performance? #2
Yep that's about right. It was a bit warm here yesterday, lower 30s the snow had a lot of moisture content so it doesn't throw as far as it does when it's 10 or so. Fortunately your machine has plenty of power to move it again if it doesn't make it all the way across the drive way.. Some days when it's real cold and the wind is blowing it will go a couple of hundred feet..
/ 2305 w/ 47" front blower performance? #3
I feel the same way. Does not seem to have the power my old belt drive singlestage snowthrower did. It will go thru the snow ok but only throws it about 15 feet. Makes me wish the impeller would spin faster running at 3500 rpms
/ 2305 w/ 47" front blower performance? #5
Running somewhere around 25-3000 I can blown snow from one side of a two lane road to the other side. Guessing 25-30' ...Have to admit still better than taking a shovel and trying to shovel it that far,especially when you are dealing with 18-30" of snow.
Wetter snow maybe only 20-25' .. But like I stated above ,very seldom do I run my at 3000 rpm.. Far less vibration at lower rpm and happy with the distance it is throwing at that speed.
/ 2305 w/ 47" front blower performance? #6
i agree . i posted this but no one really agreed with it. i may look at it closer to see how hard install is. gets nothing but rave reviews.
Snowblower Impeller Kit
only 20 feet ?!?! That's whimpy, my old snapper two stage threw about 30 feet.
My Honda HS724 will throw 50 feet all day long. An unfair comparison, I suppose.
We got at least another foot of wet stuff yesterday and last night. I'm so glad I bought this. I would still be out there plowing if it wasn't for the blower.
Looking at it, it appears you wound need to pull the impeller to install that kit.
/ 2305 w/ 47" front blower performance? #8
Ironhand,
Yeah, 20' give or take seems about right; and I think you're right that is isn't a fair comparison with a 724. I've had (stress HAD) a walk behind,and I think they are different machines.
The JD will make a 48" hole through the 2-1/2' bank left by the plow trucks at the end of the driveway and throw the snow 20' while doing it. One more pass and the hole is 8' wide!
My walk behind might have thrown snow 20, 30, 40 even 50' but when I got to the end of the driveway I'd usually have a workout fighting up/over and through that bank or walk back up to the house and get a shovel to break through the bank left by the snowplows.
That said, I'm not sure if the impeller kit is a big improvement. I don't know if these rigs (2305/2210) have the horsepower and impeller speed to really throw the snow very far regardless of how tight the impeller tolerances are.
Joe
/ 2305 w/ 47" front blower performance? #9
My 2305/47" seems to throw much farther than that depending upon conditions. My driveway is about 25-30' wide and I can throw it way over the edge depending upon the angle of the chute, type of snow and speed. I do find that the speed I go at effects the throwing distance drastically and not from slowing it down, something about how it gets into the blower or something maybe. I've thrown 40'+ easy when I get it just right and the output looks like a square extruded tube of snow. If I go to slow for the 2nd pass for the 'moustache' snow it'll throw it only maybe 10' unless I speed up and load up the blower.
/ 2305 w/ 47" front blower performance? #10
Lots of variables here - amount of snow, weight of snow (powder or heavy), wind, tractor speed. I have two of these blowers - one on a 2210 - similar to your machine - and one on a 445. The performance you're describing is normal for a foot of heavy snow. Remember the faster you go, the more you load the machine and the shorter the throw. If you've got a foot of light snow or powder, these blowers will thow much further than 20' - more like 50'.
/ 2305 w/ 47" front blower performance? #11
You will also find that the blower will throw snow
further to the right, due to the direction of the
impellar. When you rotate the chute to the left,
the snow has to come up into the chute and change
directions and go against the chute harder. When I throw
to the right, I can go 20-30 with most heavy snow, some light
snow will ,as they say , go with the wind forever it seems!
had 14" last nite, lighter variety, then this morning
got another 14" of the wet stuff, and that 47 on my 445
is an absolute animal. I watch other people try to plow with
pickups, make a mess, and other blowers that just move
the snow to the edge of the driveway where it has to be moved
twice, and then only up on the banks. my snow is piled 20' off
the driveway, and rarely accumulates in depth due to the
compaction as it hits the ground going that far!
and I never have to move it twice.
:D
/ 2305 w/ 47" front blower performance? #12
further to the right, due to the direction of the impellar.
:D
Thanks Dutch, I never thought about that.
I agree that the 47 is an animal. I keep thinking that I want a blade for my Ford, because it'd be warmer and faster, but every time I move a big snow with the blower I think that there is no way I could do this with a blade. I'd just end up moving it again with the blower once the banks got too close.
Joe
/ 2305 w/ 47" front blower performance? #13
here's some pics from yesterday, did the driveway
thursday nite, about 12", lighter stuff, then did
it again friday morning after another foot of heavy wet
stuff...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
