225 running hot
   / 225 running hot #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
Tractor runs hot in about 30 min of hard use. I have been running a rotary cutter a lot and I know it puts a lot of debris in the system.I clean the screen often and blow and wash the radiator when I get home. Plenty of coolant and the fan is working. I still feel like I am not getting enough airflow. Anybody cracked the code on this?
   / 225 running hot #2
What speed range are you running in? If traveling in Mid or High at 1/2 pedal stroke or less, try dropping down to next lower range at full pedal. This will give equal trave speed but require somewhat lower HST pressure plus move more oil through the system resulting in cooler hysraulic temperature at the cooler. Hotter the oil cooler is, means warmer the air is passing through the radiator.
Just a thought, but worth a try.
   / 225 running hot
You just confirmed part of my problem. I have a hydraulic leak and was running low on fluid. less fluid means less cooling means more heat to deal with means hotter temps.
2018 FORD EXPEDITION (A51406)
2018 FORD...
Case CX210D Excavator (A50514)
Case CX210D...
2014 UTILITY 53FT DRY VAN TRAILER (A51222)
2014 UTILITY 53FT...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2012 Ford F-250...
2005 Featherlite Double Deck Stock Trailer (A50514)
2005 Featherlite...
2022 CATERPILLAR 305CR EXCAVATOR (A51242)
2022 CATERPILLAR...
