2210D rer end easy to repair!
   / 2210D rer end easy to repair! #1
sgtdiesel
VA
YM 2210D
Finished removing, replacing and reinstalling final drive gear on my YM 2210D rear. What an easy to work on diff, gear and PTO set-up. Many say it is difficult work by yourself or without "special" pliers etc. Don't be afraid to jump in...its simple and I did it all with basic hand tools.
I took out the diff for inspection and reintalled it in the process. Have a couple chipped teeth (minor on the outer ring gear). Simple Simple simple....
   / 2210D rer end easy to repair! #2
The hardest thing on tractors is that you find large nuts and bolts on occasion. A 1-1/2 nut can be intimidating to some.
A tractor your size is still small enough to have workable fasteners and as you found out, is dead simple to deal with once you're in there.
jb
40'' root grapple (A53421)
40'' root grapple...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
1 pallet of pipe (A53117)
1 pallet of pipe...
