2210D rear brake pinion broke...help
   / 2210D rear brake pinion broke...help #1
sgtdiesel
VA
YM 2210D
Got the rear end disassembled this AM (really no big chore either).
Here is what I found: The stub end of the brake pinion is sheared off. I need another brake shaft (left side when seated in the operators seat).
Any sources out there and ~cost? I am going to call Wayne up at LMTC for a source this evening. Whew sure glad it was a simple solution with little detectable metal in the oil.
OK, now lets get her back together, I have work to do...time's a wasting!
Would you like photos of the rear emptied of the PTO assembly, axle and left axle housing removed? For a tractor so old, the internals are in great shape. very little burnish on the teeth and the splined shaft couplers are still tight!
Yanmar is a well engineered and strong ...for a small tractor, everything is beefed!
   / 2210D rear brake pinion broke...help #2
Pictures? You bet! I am a internet tractor voyeur.
jb
2016 CAT 325FL CR (A47477)
2016 CAT 325FL CR...
2 Drawer Metal Filing Cabinets (A51695)
2 Drawer Metal...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
MOBILE OFFICE CONTAINER (A53843)
MOBILE OFFICE...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
