2210d has died
   / 2210d has died #1
jackqm
So my old 2210d finally had a major failure. Was running good and in the middle of tearing out old concrete when I noticed the oil light flicker a few times. Stopped and checked oil, added a little and went back at it. A few minutes later it flickered again then engine acted like it was under heavy load with no load present, a couple seconds later engine froze.
I'm guessing a main bearing froze.
I have had the old girl for about 14 years, has koyker backhoe and koyker 80 fel, been a great little tractor.
Any opinion on whether it's worth fixing, or time to go pick up the new Branson 3520h I have been drooling over?
Not sure what it would be worth as is selling it outright? Heck not even sure what it would be worth if I went ahead and did a rebuild?
   / 2210d has died #2
If it didn't get the crank I would think it would sure be worth a rebuild. Would have to be cheaper than the drooled over tractor. I guess until she is opened up nothing could be for sure.
The loader and backhoe already fit. Unless you buy a unit with them already attached you might have to do some rework. .
   / 2210d has died #3
I would do a rebuild for sure... Where are you located.
   / 2210d has died
I am in Eastern Oregon.
Yes the tractor I am looking at has a hoe and FEL already on it, much stronger on both accounts then the koyker.
I threw it on craiglist to see if there was any bites and looks like I may have a buyer... So will see how that goes.
   / 2210d has died #5
Sorry to hear about your loss...Let us know how everything turns out. I agree, if crank is ok I would rebuild as well. If the Craig's list guy doesn't buy it send me a PM.
   / 2210d has died #6
I would at least drop the pan and have a look. It might have just spun a $20 rod bearing, also would put a socket on the crankshaft nut and see if it will turn over.
   / 2210d has died #7
Did you get your 2210 figured out? Hopefully it was nothing to major.
10X12 PUMP (A52472)
10X12 PUMP (A52472)
2017 MITSUBISHI OUTLANDER SPORT (A52472)
2017 MITSUBISHI...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2018 Nissan Sentra Passenger Car (A51694)
2018 Nissan Sentra...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
