2210 JD TURF VS. R1S
   / 2210 JD TURF VS. R1S #1
BREW
DOES ANYONE HAVE ANY SUGGESTIONS ON USE OF TURF TIRES OVER THE BAR TREAD DESIGNS. I INTEND TO PURCHASE A 2210 NEXT WEEK. THE DEALER HAS REPETIVELY MADE THE COMMENT THAT I WON'T BE HAPPY WITH TURF TIRES. I HAVE A 970(APPROX. 38HP)FRONT WHEEL ASSIST WITH BAR TIRES, FEL, BOXBLADE, 6'ROTORY CUTTER, CHISEL PLOW, DISK, ETC. I ONLY NEED THE 2210 FOR YARD MOWING PURPOSE ONLY(3 AC.). ANYWAY, I WOULD BE INTERESTED IN ANY FEEDBACK ON THE 2210 WITH TURF TIRES.
DOES ANYONE HAVE ANY COMMENTS ON THE 2210-GOOD OR BAD, ANY PROBLEMS ARISING, FOR A SERIOUS POTENTIAL BUYER-MYSELF.
THANKS JAMES /forums/images/graemlins/smile.gif
   / 2210 JD TURF VS. R1S #2
James,
If all you are going to do with the 2210 is yard mowing, I can't understand why the dealer would recommend R1 tires. Much, much too aggressive for the lawn. I have a JD 755 which is similar in size to the 2210. It has turf tires which have worked very well for mowing. Good Luck.
Jeff
JEFF,
EXACTLY WHAT I'M THINKING. IT IS GOING TO REQUIRE HIM(DEALER) TO CHANGE OUT TO TURF TIRES, OR ORDER IN A TRACTOR ALREADY SET FOR AS REQUESTED. THANKS FOR YOUR INPUT.
JAMES
   / 2210 JD TURF VS. R1S #4
There was a good thred about tires quite awile ago. Heres the link........
ag tire rule
Happy reading.
THANKS FOR THE REPLY AND ADDRESS TO THE ARTICLE, VERY WELL PUT TO SAY THE LEAST.
THANKS AGAIN,
JAMES
   / 2210 JD TURF VS. R1S #6
if all u are going to do with that machine is cut grass, then by all means get the turfs.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
3 WHEEL ELECTRIC GOLF CART (A55745)
3 WHEEL ELECTRIC...
2020 CHEVROLET SILVERADO (A55745)
2020 CHEVROLET...
