2210 Battery
/ 2210 Battery #1
cford
Buffalo, NY
John Deere 2210
After reading all that was going on with corrosion on the factory batteries I decided not to take the chance. If anyone is interested a Optima 51 will fit in a 2210. Just have to keep the hold down loose until you get the front end back on because the Optima is a little wider.
/ 2210 Battery #2
Did you get the 51 or the 51R?
/ 2210 Battery
I used the 51. My Battery had the positive terminal on the back right side. The 51R would have put it on the front right. The cable probably would have reached but I decided to use the 51 and just spin it around.
Just some additional info, you can't tighten the battery all the way down until you get the front end back on. I had to lift the battery a little to get the bottom notches on the front end into the slots. Then I tightened the battery down. I think the Optima is a little wider than the origional one.
/ 2210 Battery #4
Thanks for the heads up. Last time I looked in there I thought the 51 was the right choice and you just confirmed it.
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
(INOP) 1986 INTERNATIONAL S1900 FLATBED TRUCK (A63291)
(INOP) 1986...
Challenger MT800/MT800B Series Tractor Service and Parts Manuals (A63117)
Challenger...
Engine (A59228)
Engine (A59228)
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2018 Dodge Journey SUV (A61574)
2018 Dodge Journey...
