2210 4' or 5' rotary cutter
   / 2210 4' or 5' rotary cutter #1
Anonymous Poster
Epic Contributor
2210 4\' or 5\' rotary cutter
Anyone have a 5' rotary cutter on their 2210?
Would a 5' cutter be too much for the 2210?
   / 2210 4' or 5' rotary cutter #2
Re: 2210 4\' or 5\' rotary cutter
Probably, but what are you planning to cut with it?
   / 2210 4' or 5' rotary cutter #3
I have the LX-4 and kinda wish I had gone with the LX-5 against what my dealer suggested. The 2210 has more then enough power LX-4 for cutting tall grass and a bush or two. If I were to be buying again I would most likely get the LX-5 but I have grass only to cut.
Bill
I have been cutting with a borrowed 5' Howse for the past couple of weeks. I seems to be cutting just fine, but I definitely need my FEL on to run it. Gets a little back heavy.
   / 2210 4' or 5' rotary cutter #5
I think the 5 ft. rotary cutter would be a bit too much for the 2210. It may hook up but the hp and drive train strength, as well as additional weight handling ability is just not there. That could get you in some serious trouble on hills and slopes. Stick with the LX 4.
I bought a used 403 which is the old-style 4" rotary for my 2210. I probably have the HP to run a 5- footer but it would be all out of proportion to the rest of the tractor, even the 4-footer seems big. The 4 footer may take longer but I think it's a safer match to the tractor's size and capacities.
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2016 KOMATSU PC210LC-11 EXCAVATOR (A52707)
2016 KOMATSU...
2013 Ford F-550 4x4 10ft. Flatbed Truck (A55852)
2013 Ford F-550...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
