Mowing 2200 mower and backblade
   / 2200 mower and backblade #1
SootyBob
Holly, MI
Kubota BX2200
Got my baby today. Wheee. Is there a way to set the back blade high enough to mow with the mid mount mower with out removing the blade? Also, is there a way to find answers to these newbee questions on this site with out posting.
TIA,
Sooty Bob
   / 2200 mower and backblade #2
The lift arms can be pinned to tractor on each side. This would prevent your blade from dropping when you lowered the mower. You would have to block up under your blade to do this safely. I pin my lift arms when mowing because I pull a vacuum trailer. The lift arms would interfer with the trailer as they work on the same lift system as the mower. You can adjust the lift adjustment screw under the right rear fender but you probably could not let your mower down far enough without the blade dragging the ground.
   / 2200 mower and backblade #3
<font color=blue>Also, is there a way to find answers to these newbee questions on this site with out posting.</font color=blue> If your concerned about asking the obvious, don't be. We were all newbies at first (and I, for one, still have a lot more to learn /w3tcompact/icons/smile.gif).
You can use the search feature to find out what has been asked before. Helps to select 'All Forums' (never know what category the pertinent subject may lie under… and we do get off topic at times within the threads /w3tcompact/icons/wink.gif). I also find it helpful on the Search Options to select 'And' rather than entire phrase. I usually start with a '1-month' range, and if no hits, start working back in time.
Also, Welcome to TBN!
Roy
   / 2200 mower and backblade #4
Sootybob, I would not mow witht the FEL and a rear blade installed. You will be knocking things over left and right. Not sure what you had before /w3tcompact/icons/smile.gif but if it was something like a Murray (best dang tractor in the universe) you bump into something and likely no damage but to the Murray but run into something with the BX and SMACKO!! fence gone!, dog flat! house caved in!, car squished, wife not happy!--you get the picture! Have fun. J
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2022 Electric Mobility Scooter (A55853)
2022 Electric...
2019 Ford Fiesta SE Hatchback (A55853)
2019 Ford Fiesta...
2022 Harley Davidson Electraglide (A55973)
2022 Harley...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
